SetColumnName 方法 (ActiveX)
为列设置名称。 支持的平台:仅限 Windows 签名VBA: object.SetColumnName nIndex, name
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_ColumnName()
' This example adds a table in model space and sets and gets a column name
Dim MyModelSpace As AcadModelSpace
Set MyModelSpace = ThisDrawing.ModelSpace
Dim pt(2) As Double
Dim MyTable As AcadTable
Dim cName As String
Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
Call MyTable.SetColumnName(2, "Test Name")
MsgBox "The column name is: " & vbCrLf & _
MyTable.GetColumnName(2)
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_ColumnName()
;; This example adds a table in model space and sets and gets a column name
(setq pt (vlax-3d-point 0 0 0))
(setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
(vla-SetColumnName MyTable 2 "Test Name")
(alert (strcat "The column name is: \n"
(vla-GetColumnName MyTable 2)))
(vla-ZoomExtents acadObj)
GMT+8, 2026-10-27 11:16
