SetColorBookColor 方法 (ActiveX)
指定现有颜色书中的颜色名称。 支持的平台:仅限 Windows 签名VBA: object.SetColorBookColor BookName, ColorName
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_SetColorBookColor()
' This example draws a line and specifies a color name
' from an existing color book.
Dim FirstColor As AcadAcCmColor
Set FirstColor = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(CStr(AcadApplication.Version), 2))
FirstColor.SetRGB 80, 100, 244
Dim line As AcadLine
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
ZoomAll
FirstColor.SetColorBookColor "PANTONE+ Solid Uncoated", "PANTONE Yellow 012 U"
line.TrueColor = FirstColor
可视化 LISP: (vl-load-com)
(defun c:Example_SetColorBookColor()
;; This example draws a line and specifies a color name
;; from an existing color book.
(setq FirstColor (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
(vla-SetRGB FirstColor 80 100 244)
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
(vla-ZoomAll acadObj)
(vla-SetColorBookColor FirstColor "PANTONE+ Solid Uncoated" "PANTONE Yellow 012 U")
(vla-put-TrueColor lineObj FirstColor)
(vlax-release-object FirstColor)
GMT+8, 2026-10-28 07:35
