ObjectARX 开发指南
重命名图层状态 (.NET)
2023-1-1 12:50| 发布者: admin| 查看: 2723| 评论: 0|来自: AutoCAD
该方法在图形中将保存的图层状态从一个名称重命名为另一个名称。以下代码将 ColorLinetype 图层设置重命名为 OldColorLinetype。RenameLayerState
VB.NET
<CommandMethod("RenameLayerState")> _
Public Sub RenameLayerState()
    '' Get the current document
    Dim acLyrStMan As LayerStateManager
    acLyrStMan = acDoc.Database.LayerStateManager
    Dim sLyrStName As String = "ColorLinetype"
    Dim sLyrStNewName As String = "OldColorLinetype"
    If acLyrStMan.HasLayerState(sLyrStName) = True And _
       acLyrStMan.HasLayerState(sLyrStNewName) = False Then
        acLyrStMan.RenameLayerState(sLyrStName, sLyrStNewName)
    End If
C#
[CommandMethod("RenameLayerState")]
public static void RenameLayerState()
    // Get the current document
    LayerStateManager acLyrStMan;
    acLyrStMan = acDoc.Database.LayerStateManager;
    string sLyrStName = "ColorLinetype";
    string sLyrStNewName = "OldColorLinetype";
    if (acLyrStMan.HasLayerState(sLyrStName) == true &&
        acLyrStMan.HasLayerState(sLyrStNewName) == false)
        acLyrStMan.RenameLayerState(sLyrStName, sLyrStNewName);
VBA/ActiveX 代码参考
    Dim oLSM As AcadLayerStateManager
    Set oLSM = ThisDrawing.Application. _
                   GetInterfaceObject("AutoCAD.AcadLayerStateManager.24")
    oLSM.SetDatabase ThisDrawing.Database
    oLSM.Rename "ColorLinetype", "OldColorLinetype"
GMT+8, 2026-11-29 11:49
