SetCellValue 方法 (ActiveX)
设置给定行和列的单元格值。 支持的平台:仅限 Windows 签名VBA: object.SetCellValue row, col, val
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_CellManipulation()
' This example adds a table in model space and sets and gets a column name
Dim MyModelSpace As AcadModelSpace
Set MyModelSpace = ThisDrawing.modelSpace
Dim pt(2) As Double
Dim MyTable As AcadTable
Dim cName As String
Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
Call MyTable.SetCellDataType(2, 2, acLong, acUnitDistance)
Call MyTable.SetCellFormat(1, 3, "testFormat")
Call MyTable.SetCellState(4, 3, acCellStateContentLocked)
Call MyTable.SetCellValue(1, 4, 5)
MsgBox MyTable.GetCellValue(1, 4) & " is the test cell's value "
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_CellManipulation()
;; This example adds a table in model space and sets and gets a column name
(setq pt (vlax-3d-point 0 0 0))
(setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
(vla-SetCellDataType MyTable 2 2 acLong acUnitDistance)
(vla-SetCellFormat MyTable 1 3 "testFormat")
(vla-SetCellState MyTable 4 3 acCellStateContentLocked)
(vla-SetCellValue MyTable 1 4 5)
(alert (strcat (itoa (vlax-variant-value (vla-GetCellValue MyTable 1 4))) " is the test cell's value."))
(vla-ZoomExtents acadObj)
GMT+8, 2026-10-28 04:49
