SetBulge 方法 (ActiveX)
设置折线在给定索引处的凸起。 支持的平台:仅限 Windows 签名VBA: object.SetBulge Index, Value
返回值 (RetVal)无返回值。 言论折线:如果折线属性不是 。TypeacSimplePoly 凸起是所选顶点与折线顶点列表中的下一个顶点之间的弧所包含角度的 1/4 的切线。负凸起值表示圆弧从所选顶点顺时针方向移动到下一个顶点。凸起 0 表示直线段,凸起 1 表示半圆。 例子VBA: Sub Example_SetBulge()
' This example creates a lightweight polyline in model space.
' It then finds and changes the bulge for a given segment.
Dim points(0 To 11) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 1
' Create a lightweight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
ZoomAll
' Find the bulge of the third segment
Dim currentBulge As Double
currentBulge = plineObj.GetBulge(3)
MsgBox "The bulge for the third segment is " & plineObj.GetBulge(3), , "SetBulge Example"
' Change the bulge of the third segment
plineObj.SetBulge 3, -0.5
plineObj.Update
MsgBox "The bulge for the third segment is now " & plineObj.GetBulge(3), , "SetBulge Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SetBulge()
;; This example creates a lightweight polyline in model space.
;; It then finds and changes the bulge for a given segment.
;; Define the 2D polyline points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
(vlax-safearray-fill points '(1 1
1 2
2 2
3 2
4 4
4 1
;; Create a lightweight Polyline object in model space
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-ZoomAll acadObj)
;; Find the bulge of the third segment
(setq currentBulge (vla-GetBulge plineObj 3))
(alert (strcat "The bulge for the third segment is " (rtos (vla-GetBulge plineObj 3) 2)))
;; Change the bulge of the third segment
(vla-SetBulge plineObj 3 -0.5)
(vla-Update plineObj)
(alert (strcat "The bulge for the third segment is now " (rtos (vla-GetBulge plineObj 3) 2)))
GMT+8, 2026-10-28 10:50
