SelectAtPoint 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 496| 评论: 0|原作者: admin|来自: AutoCAD
选取通过给定点的对象并将其放入选择集中。
object.SelectAtPoint Point, FilterType, FilterData
类型:SelectionSet
此方法应用到的对象。
点
访问:仅输入
类型:变体(双打的三元素阵列)
指定用于选择的点的 3D UCS 坐标。
筛选类型
访问:仅输入;自选
类型:变体
指定要使用的筛选器类型的 DXF 组代码。
筛选数据
访问:仅输入;自选
类型:变体
要筛选的值。
返回值 (RetVal)
无返回值。
此方法支持过滤机制。
PICKBOX 系统变量会影响对象选择。
有关更多选择模式选项,请参见 、 和 方法。SelectSelectByPolygonSelectOnScreen
Sub Example_SelectAtPoint()
    ' This example adds objects to a selection set by identifying a point.
    ' At first all objects at the point are added to the selection set. Then
    ' only circle objects at the point are added to the selection set.
    ' Create the selection set
    Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET1")
    ' Add to the selection set all the objects that lie at point(6.8,9.4,0)
    Dim point(0 To 2) As Double
    point(0) = 6.8: point(1) = 9.4: point(2) = 0
    ssetObj.SelectAtPoint point
    ' Add to the selection set all the Circles that lie at point (6.8,9.4,0)
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = "Circle"
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ssetObj.SelectAtPoint point, groupCode, dataCode
(defun c:Example_SelectAtPoint()
    ;; This example adds objects to a selection set by identifying a point.
    ;; At first all objects at the point are added to the selection set. Then
    ;; only circle objects at the point are added to the selection set.
    ;; Create the selection set
    (setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_SSET1"))
    ;; Add to the selection set all the objects that lie at point(6.8,9.4,0)
    (setq point (vlax-3d-point 6.8 9.4 0))
    (vla-SelectAtPoint ssetObj point)
    (alert (strcat "Objects selected: " (itoa (vla-get-Count ssetObj))))
    (vla-Clear ssetObj)
    ;; Add to the selection set all the Circles that lie at point (6.8,9.4,0)
    (setq gpCode (vlax-make-safearray vlax-vbInteger '(0 . 0)))
    (vlax-safearray-put-element gpCode 0 0)
    (setq dataValue (vlax-make-safearray vlax-vbVariant '(0 . 0)))
    (vlax-safearray-put-element dataValue 0 "Circle")
    (vla-SelectAtPoint ssetObj point gpCode dataValue)
    (vla-Delete ssetObj)
GMT+8, 2026-10-27 04:48
