ScaleEntity 方法 (ActiveX)
在 X、Y 和 Z 方向上平均缩放对象。 支持的平台:仅限 Windows 签名VBA: object.ScaleEntity BasePoint, ScaleFactor
返回值 (RetVal)无返回值。 言论![]() ScaleFactor = 0.5 和 ScaleFactor = 2 例子VBA: Sub Example_ScaleEntity()
' This example creates a lightweight polyline
' and then scales that polyline.
' Create the polyline
Dim points(0 To 11) As Double
points(0) = 1: points(1) = 2
points(2) = 1: points(3) = 3
points(4) = 2: points(5) = 3
points(6) = 3: points(7) = 3
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 2
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = True
ZoomAll
MsgBox "Scale the polyline by 0.5", , "ScaleEntity Example"
' Define the scale
Dim basePoint(0 To 2) As Double
Dim scalefactor As Double
basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
scalefactor = 0.5
' Scale the polyline
plineObj.ScaleEntity basePoint, scalefactor
ZoomAll
MsgBox "Scale completed.", , "ScaleEntity Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ScaleEntity()
;; This example creates a lightweight polyline
;; and then scales that polyline.
;; Create the polyline
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
(vlax-safearray-fill points '(1 2
1 3
2 3
3 3
4 4
4 2
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-put-Closed plineObj :vlax-true)
(vla-ZoomAll acadObj)
(alert "Scale the polyline by 0.5")
;; Define the scale
(setq basePoint (vlax-3d-point 4 4.25 0)
scalefactor 0.5)
;; Scale the polyline
(vla-ScaleEntity plineObj basePoint scalefactor)
(alert "Scale completed.")
GMT+8, 2026-11-15 11:51
