Save 方法 (ActiveX)
保存一个文档或一组图层属性设置;菜单组不再受支持。 支持的平台:仅限 Windows 签名 - LayerStateManagerVBA: object.Save Name, Mask
签名 - MenuGroupVBA: object.Save MenuFileType 返回值 (RetVal)无返回值。 言论文档:将文档保存到安全 URL 时,会出现一个对话框,提示用户输入必要的密码信息。 菜单组:此方法对 AutoCAD 2006 或更高版本中的菜单组无效。在将来的版本中,此方法将从对象中删除。MenuGroup 例子VBA: Sub Example_Save()
' The following example saves current drawing
ThisDrawing.Save
Sub Example_Save_LayerSettings()
' The following code saves the color and linetype settings
' of the current layer.
Dim oLSM As AcadLayerStateManager
' Access the LayerStateManager object
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(CStr(AcadApplication.Version), 2))
' Associate the current drawing database with LayerStateManager
oLSM.SetDatabase ThisDrawing.Database
oLSM.Save "ColorLinetype", acLsColor + acLsLineType
可视化 LISP: (defun c:Example_Save()
;; The following example saves current drawing
(vla-Save doc)
(defun c:Example_Save_LayerSettings()
;; The following code saves the color and linetype settings
;; of the current layer.
;; Access the LayerStateManager object
(setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
;; Associate the current drawing database with LayerStateManager
(vla-SetDatabase oLSM (vla-get-Database doc))
(vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
GMT+8, 2026-9-16 02:52
