Restore 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 599| 评论: 0|原作者: admin|来自: AutoCAD
恢复一组图层属性设置。
object.Restore Name
类型:LayerStateManager
此方法应用到的对象。
名字
访问:仅输入
类型:字符串
要恢复的已保存图层设置的名称。
返回值 (RetVal)
无返回值。
该方法使用与保存的设置关联的属性来标识要恢复的图层属性。RestoreMask
Sub Example_RestoreLayerSettings()
    ' The following code restores color and linetype settings
    ' that were saved as "ColorLineType".
    Dim oLSM As AcadLayerStateManager
    Set oLSM = ThisDrawing.Application. _
       GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(CStr(AcadApplication.Version), 2))
    oLSM.SetDatabase ThisDrawing.Database
    oLSM.Restore "ColorLinetype"
(defun c:Example_Restore()
    ;; The following code restores color and linetype settings
    ;; that were saved as "ColorLineType."
    ;; Access the LayerStateManager object.
    (setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
    (vla-SetDatabase oLSM (vla-get-Database doc))
    (vla-Restore oLSM "ColorLinetype")
GMT+8, 2026-11-3 15:04
