RenameProfile 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 912| 评论: 0|原作者: admin|来自: AutoCAD
重命名指定的配置文件。
object.RenameProfile origProfileName, newProfileName
类型:PreferencesProfiles
此方法应用到的对象。
origProfileName
访问:仅输入
类型:字符串
当前配置文件名称。
newProfileName (新配置文件名称)
访问:仅输入
类型:字符串
配置文件的新名称。
返回值 (RetVal)
无返回值。
Sub Example_RenameProfile()
    ' This example renames an existing profile.
    ' You can see the renamed profile under Options/Profiles
    ' *Note: This example relies on the default profile "<<Unnamed Profile>>".
    ' If this profile has already been renamed or removed, be sure to change the
    ' name of the SourceProfile to one that currently exists.
    Dim ACADPref As AcadPreferencesProfiles
    Dim SourceProfile As String, DestinationProfile As String
    ' Get the profiles preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Profiles
    ' Rename the default profile
    On Error GoTo ERRORTRAP
    SourceProfile = "<<Unnamed Profile>>"
    DestinationProfile = "NEW_PROFILE_NAME"
    ACADPref.RenameProfile SourceProfile, DestinationProfile
    MsgBox "We have just renamed the profile " & SourceProfile & " to " & DestinationProfile
    Exit Sub
ERRORTRAP:
    If Err.Description <> "" Then
        MsgBox "The default profile '" & SourceProfile & "' cannot be found, please use a different source profile."
    End If
(defun c:Example_RenameProfile()
    ;; This example renames an existing profile.
    ;; You can see the renamed profile under Options/Profiles
    ;; *Note: This example relies on the default profile "<<Unnamed Profile>>".
    ;; If this profile has already been renamed or removed, be sure to change the
    ;; name of the SourceProfile to one that currently exists.
    ;; Rename the default profile
    (setq sourceProfile "<<Unnamed Profile>>"
          destinationProfile "NEW_PROFILE_NAME")
    (setq err (vl-catch-all-apply 'vla-RenameProfile (list (vla-get-Profiles preferences) sourceProfile destinationProfile)))
    (if (= (type err) 'VL-CATCH-ALL-APPLY-ERROR)
        (alert (strcat "The default profile '" SourceProfile "' cannot be found, please use a different source profile."))
        (alert (strcat "We have just renamed the profile " SourceProfile " to " DestinationProfile))
GMT+8, 2026-10-28 06:06
