Rename 方法 (ActiveX)
重命名字典中的项目或一组已保存的图层设置。 支持的平台:仅限 Windows 签名VBA: object.Rename OldName, NewName
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_Rename()
' This example creates a dictionary and adds
' a custom object to that dictionary. It then
' renames the object in the dictionary.
Dim dictObj As AcadDictionary
Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
' Load the ObjectARX application that defines the custom object.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX application.
ThisDrawing.Application.LoadArx "MyARXApp.dll"
' Create the custom object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As AcadObject
keyName = "OBJ1"
className = "CAsdkDictObject"
Set customObj = dictObj.AddObject(keyName, className)
' Rename the object
dictObj.Rename keyName, "NewKeyName"
Public Sub Example_RenameLayerSettings()
' This example renames a set of saved layer settings from
' "ColorLinetype" to "OldColorLinetype."
Dim oLSM As AcadLayerStateManager
' Access the LayerStateManager object.
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(CStr(AcadApplication.Version), 2))
' Associate the current drawing database with the
' LayerStateManager object.
oLSM.SetDatabase ThisDrawing.Database
' Rename the saved layer settings.
oLSM.Rename "ColorLinetype", "OldColorLinetype"
可视化 LISP: (vl-load-com)
(defun c:Example_Rename()
;; This example creates a dictionary and adds
;; a custom object to that dictionary. It then
;; renames the object in the dictionary.
(setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
;; Load the ObjectARX application that defines the custom object.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX application.
(vla-LoadArx acadObj "MyARXApp.dll")
;; Create the custom object in the dictionary
(setq keyName "OBJ1")
(setq className "CAsdkDictObject")
(setq customObj (vla-AddObject dictObj keyName className))
;; Rename the object
(vla-Rename dictObj keyName "NewKeyName")
(defun c:Example_RenameLayerSettings()
;; This example renames a set of saved layer settings from
;; "ColorLinetype" to "OldColorLinetype."
;; Access the LayerStateManager object.
(setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
;; Associate the current drawing database with the
;; LayerStateManager object.
(vla-SetDatabase oLSM (vla-get-Database doc))
(vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
;; Rename the saved layer settings.
(vla-Rename oLSM "ColorLinetype" "OldColorLinetype")
GMT+8, 2026-10-27 04:11
