RemoveItems 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 766| 评论: 0|原作者: admin|来自: AutoCAD
从组或选择集中删除指定项目。
object.RemoveItems Objects
类型:组、SelectionSet
此方法应用到的对象。
访问:仅输入
类型:变体(对象数组)
要删除的对象数组。
返回值 (RetVal)
无返回值。
从组或选择集中移除的项目将保留在图形中;它们不再与组或选择集相关联。此功能模拟该方法中的功能,只不过允许您指定要删除的单个项,而不是整个选择集。ClearRemoveItems
此方法与 and 方法的不同之处在于它不会从图形中删除对象。DeleteErase
Sub Example_RemoveItems()
    ' This example creates a selection set and several objects.
    ' It adds the objects to the selection set, and then
    ' removes two of the objects from the selection set.
    ' Create the new selection set
    Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SELECTIONSET")
    ' Create a Ray object in model space
    Dim rayObj As AcadRay
    Dim basePoint(0 To 2) As Double
    Dim SecondPoint(0 To 2) As Double
    basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
    SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
    Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
    ' Create a polyline object in model space
    Dim points(0 To 5) As Double
    points(0) = 3: points(1) = 7
    points(2) = 9: points(3) = 2
    points(4) = 3: points(5) = 5
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    plineObj.Closed = True
    ' Create a line object in model space
    Dim lineObj As AcadLine
    startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
    endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
    ' Create a circle object in model space
    Dim circObj As AcadCircle
    Dim centerPt(0 To 2) As Double
    Dim radius As Double
    centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0
    radius = 3
    Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
    ' Create an ellipse object in model space
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ZoomAll
    ' Iterate through the model space collection.
    ' Collect the objects found into an array of objects
    ' to be added to the selection set.
    ReDim ssobjs(0 To ThisDrawing.ModelSpace.Count - 1) As AcadEntity
    Dim I As Integer
    For I = 0 To ThisDrawing.ModelSpace.Count - 1
        Set ssobjs(I) = ThisDrawing.ModelSpace.Item(I)
    Next
    ' Add the array of objects to the selection set
    ssetObj.AddItems ssobjs
    GoSub LISTOBJS
    ' Remove two of the objects from the selection set
    Dim removeObjects(0 To 1) As AcadEntity
    Set removeObjects(0) = ellObj
    Set removeObjects(1) = circObj
    ssetObj.RemoveItems removeObjects
    MsgBox "The ellipse and circle have been removed from the selection set."
    GoSub LISTOBJS
    Exit Sub
LISTOBJS:
    ' List all the objects in the selection set
    If ssetObj.Count = 0 Then
        MsgBox "The selection set is empty"
    Else
        For I = 0 To ssetObj.Count - 1
            MsgBox "The selection set contains: " & ssetObj.Item(I).ObjectName
        Next
    End If
    Return
(defun c:Example_RemoveItems()
    ;; This example creates a selection set and several objects.
    ;; It adds the objects to the selection set, and then
    ;; removes two of the objects from the selection set.
    ;; Create the new selection set
    (setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_SELECTIONSET"))
    ;; Create a Ray object in model space
    (setq basePoint (vlax-3d-point 3 3 0)
          secondPoint (vlax-3d-point 1 3 0))
    (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint))
    ;; Create a polyline object in model space
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(3 7
                                  9 2
				  3 5
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-put-Closed plineObj :vlax-true)
    ;; Create a line object in model space
    (setq startPoint (vlax-3d-point 0 0 0)
          endPoint (vlax-3d-point 2 2 0))
    ;; Create a circle object in model space
    (setq centerPt (vlax-3d-point 20 30 0)
          radius 3)
    (setq circObj (vla-AddCircle modelSpace centerPt radius))
    ;; Create an ellipse object in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    (vla-ZoomAll acadObj)
    ;; Iterate through the model space collection.
    ;; Collect the objects found into an array of objects
    ;; to be added to the selection set.
    (setq ssobjs (vlax-make-safearray vlax-vbObject (cons 0 (- (vla-get-Count modelSpace) 1))))
    (setq cnt 0)
    (vlax-for each-item modelSpace
        (vlax-safearray-put-element ssobjs cnt each-item)
        (setq cnt (1+ cnt))
    ;; Add the array of objects to the selection set
    (vla-AddItems ssetObj ssobjs)
    ;; List all the objects in the selection set
    (setq I 0)
    (if (= (vla-get-Count ssetObj) 0)
        (alert "The selection set is empty")
        (while (>= (1- (vla-get-Count ssetObj)) I)
            (alert (strcat "The selection set contains: " (vla-get-ObjectName (vla-Item ssetObj I))))
            (setq I (1+ I))
    ;; Remove two of the objects from the selection set
    (setq removeObjects (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element removeObjects 0 ellObj)
    (vlax-safearray-put-element removeObjects 1 circObj)
    (vla-RemoveItems ssetObj removeObjects)
    (alert "The ellipse and circle have been removed from the selection set.")
    (setq I 0)
            (setq I (1+ I))
    (vla-Delete ssetObj)
GMT+8, 2026-10-27 08:58
