Reload 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 850| 评论: 0|原作者: admin|来自: AutoCAD
Reload 方法 (ActiveX)
重新加载外部参照 (xref)。
object.Reload
类型:ExternalReference
此方法应用到的对象。
返回值 (RetVal)
无返回值。
重新加载外部参照时,参照图形的最近保存版本将加载到当前图形中。
Sub Example_Reload()
    On Error GoTo ERRORHANDLER
    ' Define external reference to be inserted
    Dim xrefHome As AcadBlock
    Dim xrefInserted As AcadExternalReference
    Dim insertionPnt(0 To 2) As Double
    Dim PathName As String
    insertionPnt(0) = 1
    insertionPnt(1) = 1
    insertionPnt(2) = 0
    PathName = "c:/AutoCAD/sample/City map.dwg"
    ' Add the external reference to the block
    Set xrefInserted = ThisDrawing.ModelSpace. _
            AttachExternalReference(PathName, "XREF_IMAGE", _
            insertionPnt, 1, 1, 1, 0, False)
    ZoomAll
    MsgBox "The external reference is attached."
    ' Reload the external reference definition
    ThisDrawing.Blocks.Item(xrefInserted.name).Reload
    MsgBox "The external reference is reloaded."
    Exit Sub
ERRORHANDLER:
    MsgBox Err.Description
(defun c:Example_Reload()
    ;; Define external reference to be inserted
    (setq insertionPnt (vlax-3d-point 1 1 0)
          pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
    ;; Add the external reference to the block
    (setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
    (vla-ZoomAll acadObj)
    (alert "The external reference is attached.")
    ;; Unload the external reference definition
    (vla-Unload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
    (vla-Regen doc :vlax-true)
    (alert "The external reference is unloaded.")
    ;; Reload the external reference definition
    (vla-Reload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
    (alert "The external reference is reloaded.")
GMT+8, 2026-10-28 04:49
