Prompt 方法 (ActiveX)
在命令行上显示提示符。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_Prompt()
' This example will use the Utility object to display a prompt to the
' AutoCAD command line. To see the results after running the example,
' switch to AutoCAD and look at the command line.
ThisDrawing.Utility.Prompt "Press any key..."
可视化 LISP: (vl-load-com)
(defun c:Example_Prompt()
;; This example will use the Utility object to display a prompt to the
;; AutoCAD command line. To see the results after running the example,
;; switch to AutoCAD and look at the command line.
(vla-Prompt (vla-get-Utility doc) "Press any key...")
GMT+8, 2026-10-27 07:15
