Move 方法 (ActiveX)
沿矢量移动对象。 支持的平台:仅限 Windows 签名VBA: object.Move Point1, Point2
返回值 (RetVal)无返回值。 言论您指定的两个点定义了一个位移向量,指示给定对象要移动多远以及移动方向。 ![]() 给定对象,并指示两个点 ![]() 移动的对象 例子VBA: Sub Example_Move()
' This example creates a circle and then performs
' a move on that circle.
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2#: center(1) = 2#: center(2) = 0#
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ZoomAll
' Define the points that make up the move vector
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
point1(0) = 0: point1(1) = 0: point1(2) = 0
point2(0) = 2: point2(1) = 0: point2(2) = 0
MsgBox "Move the circle 2 units in the X direction.", , "Move Example"
' Move the circle
circleObj.Move point1, point2
ZoomAll
MsgBox "Move completed.", , "Move Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Move()
;; This example creates a circle and then performs
;; a move on that circle.
;; Create the circle
(setq center (vlax-3d-point 2 2 0)
radius 0.5)
(setq circleObj (vla-AddCircle modelSpace center radius))
(vla-ZoomAll acadObj)
;; Define the points that make up the move vector
(setq point1 (vlax-3d-point 0 0 0)
point2 (vlax-3d-point 2 0 0))
(alert "Move the circle 2 units in the X direction.")
;; Move the circle
(vla-Move circleObj point1 point2)
(alert "Move completed.")
GMT+8, 2026-11-15 14:37
