ListARX 方法 (ActiveX)
获取当前加载的 ObjectARX 应用程序。 支持的平台:仅限 Windows 返回值 (RetVal)类型:变体 当前加载的 ObjectARX 应用程序数组。如果当前未加载任何应用程序,则返回空。 言论没有其他评论。 例子VBA: Sub Example_ListARX()
' This example gets all the loaded ObjectARX applications
' Get the list of applications
Dim appList As Variant
appList = ThisDrawing.Application.ListArx
' Iterate through the list, and display the names, if any.
If VarType(appList) <> vbEmpty Then
Dim I As Integer
For I = LBound(appList) To UBound(appList)
MsgBox "ObjectARX application name: " & appList(I)
Next
Else
MsgBox "No ObjectARX applications present."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_ListARX()
;; This example gets all the loaded ObjectARX applications
;; Get the list of applications
(setq appList (vla-ListArx acadObj))
;; Iterate through the list, and display the names, if any.
(if (/= (vlax-variant-value appList) vlax-vbEmpty)
(progn
(setq I 0
appList (vlax-variant-value appList))
(while (>= (vlax-safearray-get-u-bound appList 1) I)
(alert (strcat "ObjectARX application name: " (vlax-safearray-get-element appList I)))
(setq I (1+ I))
(alert "No ObjectARX applications present.")
GMT+8, 2026-10-27 05:24
