IsURL 方法 (ActiveX)
验证给定的 URL。 支持的平台:仅限 Windows 返回值 (RetVal)类型:布尔
言论“有效”URL 的定义取决于应用程序,因为给定的第三方应用程序可能对支持所有 Internet 协议不感兴趣。例如,尝试将用户连接到网站的应用程序可能不需要提供对 FTP 站点的访问。在此假设应用程序中,如果输入以“http://”以外的内容开头的 URL,则将返回一个值。False 此方法对 AutoCAD 的默认功能支持 FTP、HTTP、HTTPS 和 FILE 协议。 例子VBA: Sub Example_IsRemoteFile()
' This example will prompt the user for a URL to download and will verify that
' a proper URL was entered. After downloading, the example will attempt to load
' the downloaded URL as a drawing.
' * Note: Remember to delete the downloaded file from your disk drive when finished.
Dim Utility As AcadUtility
Dim URL As String, DestFile As String, FileURL As String
Set Utility = ThisDrawing.Utility ' Connect to Utility object
GETURL:
' Prompt user for a URL to download. This should be a URL to an AutoCAD drawing file.
URL = Utility.GetString(False, vbLf & "Enter the complete URL of the file you wish to download: ")
URL = Trim(URL) ' Get rid of blank spaces
If URL = "" Then Exit Sub ' Did user cancel
' Determine if user entered a valid URL; if not, prompt again
If Not (Utility.IsURL(URL)) Then
MsgBox "The URL you entered is not valid. Make sure the syntax is a valid URL."
GoTo GETURL
End If
' Download URL
Utility.GetRemoteFile URL, DestFile, True
' Display downloaded file information
MsgBox URL & " was downloaded to: " & DestFile
' Use IsRemoteFile to determine if this file was downloaded from a URL.
' If it was, display the URL it was downloaded from
' * Note: Although the results that IsRemoteFile will return are already known
' since the file was just downloaded it is important to know how this
' method can be used.
If Utility.IsRemoteFile(DestFile, FileURL) Then
MsgBox "The file: " & DestFile & " is a downloaded file and was downloaded from: " & FileURL
Else
MsgBox "The file: " & DestFile & " is not a downloaded file."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_IsRemoteFile()
;; This example will prompt the user for a URL to download and will verify that
;; a proper URL was entered. After downloading, the example will provide information
;; about the downloaded drawing.
;; * Note: Remember to delete the downloaded file from your disk drive when finished.
(setq Utility (vla-get-Utility doc)) ;; Connect to Utility object
;; Prompt user for a URL to download. This should be a URL to an AutoCAD drawing file.
(setq URL (vla-GetString Utility :vlax-false "Enter the complete URL of the file you wish to download: "))
(if (/= URL "")
(progn
(if (= (vla-IsURL Utility URL) :vlax-false)
(alert "The URL you entered is not valid. Make sure the syntax is a valid URL.")
(progn
;; Download URL
(vla-GetRemoteFile Utility URL 'DestFile :vlax-true)
;; Display downloaded file information
(alert (strcat URL " was downloaded to: " DestFile "\n"))
;; Use IsRemoteFile to determine if this file was downloaded from a URL.
;; If it was, display the URL it was downloaded from
;; * Note: Although the results that IsRemoteFile will return are already known
;; since the file was just downloaded it is important to know how this
;; method can be used.
(if (= (vla-IsRemoteFile Utility DestFile URL) :vlax-true)
(alert (strcat "The file: " DestFile " is a downloaded file and was downloaded from: " URL))
(alert (strcat "The file: " DestFile " is not a downloaded file."))
GMT+8, 2026-10-27 04:47
