IntersectWith 方法 (ActiveX)
获取绘图中一个对象与另一个对象相交的点。 支持的平台:仅限 Windows 签名VBA: RetVal = object.IntersectWith(IntersectObject, ExtendOption)
返回值 (RetVal)类型:变体(双打数组) 图形中一个对象与另一个对象相交的点数组。 言论如果两个对象不相交,则不返回任何数据。您可以请求在将一个或两个对象扩展为与另一个对象相遇时将发生的交点。例如,在下图中,Line1 是调用此方法的基对象,line3 是作为参数传递的对象。如果传递的 ExtendOption 为 ,则返回点 A,作为扩展 line1 时 line1 与 line3 相交的点。如果 ExtendOption 为 ,则不返回任何数据,因为即使扩展了 line3,它也不会与 line1 相交。acExtendThisEntityacExtendOtherEntity 如果交集类型为 并且 line2 作为参数实体传递,则返回点 B。如果 ExtendOption 为 且 line2 为参数实体,则不返回任何数据。acExtendBothEntitiesacExtendNone ![]() 例子VBA: Sub Example_IntersectWith()
' This example creates a line and circle and finds the points at
' which they intersect.
' Create the line
Dim lineObj As AcadLine
Dim startPt(0 To 2) As Double
Dim endPt(0 To 2) As Double
startPt(0) = 1: startPt(1) = 1: startPt(2) = 0
endPt(0) = 5: endPt(1) = 5: endPt(2) = 0
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
' Create the circle
Dim circleObj As AcadCircle
Dim centerPt(0 To 2) As Double
Dim radius As Double
centerPt(0) = 3: centerPt(1) = 3: centerPt(2) = 0
radius = 1
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
ZoomAll
' Find the intersection points between the line and the circle
Dim intPoints As Variant
intPoints = lineObj.IntersectWith(circleObj, acExtendNone)
' Print all the intersection points
Dim I As Integer, j As Integer, k As Integer
Dim str As String
If VarType(intPoints) <> vbEmpty Then
For I = LBound(intPoints) To UBound(intPoints)
str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2)
MsgBox str, , "IntersectWith Example"
str = ""
I = I + 2
j = j + 3
k = k + 1
Next
End If
可视化 LISP: (vl-load-com)
(defun c:Example_IntersectWith()
;; This example creates a line and circle and finds the points at
;; which they intersect.
;; Create the line
(setq startPt (vlax-3d-point 1 1 0)
endPt (vlax-3d-point 5 5 0))
(setq lineObj (vla-AddLine modelSpace startPt endPt))
;; Create the circle
(setq centerPt (vlax-3d-point 1 1 0)
radius 1)
(setq circleObj (vla-AddCircle modelSpace centerPt radius))
(vla-ZoomAll acadObj)
;; Find the intersection points between the line and the circle
(setq intPoints (vla-IntersectWith lineObj circleObj acExtendNone))
;; Print all the intersection points
(setq I 0
j 0
k 0)
(if (/= (type intPoints) vlax-vbEmpty)
(while (>= (vlax-safearray-get-u-bound (vlax-variant-value intPoints) 1) I)
(setq tempPoint (vlax-safearray->list (vlax-variant-value intPoints)))
(setq str (strcat "Intersection Point[" (itoa k) "] is: " (rtos (nth j tempPoint) 2) ","
(rtos (nth (1+ j) tempPoint) 2) ","
(rtos (nth (+ j 2) tempPoint) 2)))
(alert str)
(setq str ""
I (+ I 2)
j (+ j 3)
k (1+ k))
GMT+8, 2026-10-27 09:12
