本示例使用属性设置通过对象的线型电流。DatabaseCeltype VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("SetLinetypeCurrent")> _
Public Sub SetLinetypeCurrent()
'' Start a transaction
'' Open the Linetype table for read
Dim acLineTypTbl As LinetypeTable
acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, _
OpenMode.ForRead)
Dim sLineTypName As String = "Center"
If acLineTypTbl.Has(sLineTypName) = True Then
'' Set the linetype Center current
acCurDb.Celtype = acLineTypTbl(sLineTypName)
'' Save the changes
acTrans.Commit()
End If
'' Dispose of the transaction
End Using
[CommandMethod("SetLinetypeCurrent")]
public static void SetLinetypeCurrent()
// Start a transaction
// Open the Linetype table for read
LinetypeTable acLineTypTbl;
OpenMode.ForRead) as LinetypeTable;
string sLineTypName = "Center";
if (acLineTypTbl.Has(sLineTypName) == true)
// Set the linetype Center current
acCurDb.Celtype = acLineTypTbl[sLineTypName];
// Save the changes
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考ThisDrawing.ActiveLinetype = ThisDrawing.Linetypes.Item("Center")
相关概念父主题: |
GMT+8, 2026-10-27 05:26
