InsertMenuInMenuBar 方法 (ActiveX)
将菜单插入到 AutoCAD 菜单栏中。 支持的平台:仅限 Windows 签名VBA: object.InsertMenuInMenuBar MenuName, Index
返回值 (RetVal)无返回值。 言论菜单紧接在指定的索引位置之前插入。 例子VBA: Sub Example_InsertMenuInMenuBar()
' This example creates a new menu called TestMenu and inserts a menu item
' into it. The menu is then displayed on the menu bar.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new menu
Dim newMenu As AcadPopupMenu
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add a menu item to the new menu
Dim newMenuItem As AcadPopupMenuItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
' Display the menu on the menu bar
currMenuGroup.Menus.InsertMenuInMenuBar "TestMenu", ""
可视化 LISP: (vl-load-com)
(defun c:Example_InsertMenuInMenuBar()
;; This example creates a new menu called TestMenu and inserts a menu item
;; into it. The menu is then displayed on the menu bar.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new menu
(setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
;; Add a menu item to the new menu
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
;; Display the menu on the menu bar
(vla-InsertMenuInMenuBar (vla-get-Menus currMenuGroup) "TestMenu" "")
;; Display the menu bar
(vla-SetVariable doc "MENUBAR" 1)
GMT+8, 2026-10-27 13:42
