GetSubEntity 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 639| 评论: 0|原作者: admin|来自: AutoCAD
以交互方式获取对象或子实体。
object.GetSubEntity Object, PickedPoint, TransMatrix, ContextData [, Prompt]
类型: 实用程序
此方法应用到的对象。
访问:仅输出
类型:对象
选取的对象或子实体。可以是任何绘图对象之一。
PickedPoint
访问:仅输出
类型:变体(双打的三元素阵列)
指定所选点的 3D WCS 坐标。
TransMatrix的
访问:仅输出
类型:变体(4x4 双打阵列)
应用于此图元的转换矩阵。
上下文数据
访问:仅输出
类型:变体(多头数组)
选定对象中任何嵌套对象的对象 ID 数组。
提示
访问:仅输入;自选
类型:变体(字符串)
要显示的文本,用于提示用户输入。
返回值 (RetVal)
无返回值。
此方法要求 AutoCAD 用户通过在图形屏幕上选取一个点来选择对象。如果选取了对象或子实体,则在第一个参数中返回该对象或子实体,第二个参数将包含 WCS 坐标中选取的点。如果拾取点不在对象上,则该方法将失败。
此方法可以检索对象,即使该对象在屏幕上不可见或位于冻结图层上。
Sub Example_GetSubEntity()
    ' This example prompts the user to select on object on the screen with a mouse click,
    ' and returns some information about the selected object.
    Dim Object As Object
    Dim PickedPoint As Variant, TransMatrix As Variant, ContextData As Variant
    Dim HasContextData As String
    On Error GoTo NOT_ENTITY
TRYAGAIN:
    MsgBox "Use the mouse to click on an object in the current drawing after dismissing this dialog box."
    ' Get information about selected object
    ThisDrawing.Utility.GetSubEntity Object, PickedPoint, TransMatrix, ContextData
    ' Process and display selected object properties
    HasContextData = IIf(VarType(ContextData) = vbEmpty, " does not ", " does ")
    MsgBox "The object you chose was an: " & TypeName(Object) & vbCrLf & _
            "Your point of selection was: " & PickedPoint(0) & ", " & _
                                              PickedPoint(1) & ", " & _
                                              PickedPoint(2) & vbCrLf & _
            "This object" & HasContextData & "have nested objects."
    Exit Sub
NOT_ENTITY:
    ' If you click on empty space or do not select an entity,
    ' this error will be generated
    If MsgBox("You have not selected an object.  Click OK to try again.", _
               vbOKCancel & vbInformation) = vbOK Then
        Resume TRYAGAIN
    End If
(defun c:Example_GetSubEntity()
    ;; This example prompts the user to select on object on the screen with a mouse click,
    ;; and returns some information about the selected object.
    ;; Get information about selected object
    (vla-GetSubEntity (vla-get-Utility doc) 'Object 'PickedPoint 'TransMatrix 'ContextData "Select a subentity: ")
    ;; Process and display selected object properties
    (if (/= ContextData nil)
        (setq HasContextData " does ")
        (setq HasContextData " does not ")
    (alert (strcat "The object you chose was an: " (vla-get-ObjectName Object)
                   "\nYour point of selection was: " (rtos (vlax-safearray-get-element PickedPoint 0) 2) ", "
		                                                   (rtos (vlax-safearray-get-element PickedPoint 1) 2) ", "
		                                                   (rtos (vlax-safearray-get-element PickedPoint 2) 2)
                   "\nThis object" HasContextData "have nested objects."))
GMT+8, 2026-10-28 04:02
