GetString 方法 (ActiveX)
从用户获取字符串。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetString(HasSpaces [, Prompt])
返回值 (RetVal)类型:字符串 从用户返回的字符串。 言论AutoCAD 暂停用户输入字符串,并将结果设置为用户输入的字符串。HasSpaces 参数指定字符串是否可以包含空格。Prompt 参数指定此方法在 AutoCAD 暂停之前显示的字符串。 AutoCAD 用户可以从键盘输入字符串。如果 HasSpaces 参数为 True,则字符串可以包含空格,用户必须通过输入 [Return] 来终止它。如果 HasSpaces 为 False,则输入空白或 [Return] 将终止字符串。如果用户输入的字符超过 132 个字符,则字符串输入将继续进行,直到用户输入空格或回车符(根据 HasSpaces),但仅将前 132 个字符放入返回值中。GetString 例子VBA: Sub Example_GetString()
' This example demonstrates different ways of returning a string
' entered by a user.
Dim returnString As String
' Prompt & Input cannot contain blanks
returnString = ThisDrawing.Utility.GetString(False, "Enter text (a space or terminates input): ")
MsgBox "The string entered was '" & returnString & "'", , "GetString Example"
' Prompt & Input can contain blanks
returnString = ThisDrawing.Utility.GetString(True, "Enter text ( terminates input):")
' Prompt & Input can contain blanks, but not an empty string
Dim NoNull As Integer
NoNull = 1 ' Disallow null
ThisDrawing.Utility.InitializeUserInput NoNull
returnString = ThisDrawing.Utility.GetString(True, "Enter text ( terminates input): ")
可视化 LISP: (vl-load-com)
(defun c:Example_GetString()
;; This example demonstrates different ways of returning a string
;; entered by a user.
;; Prompt & Input cannot contain blanks
(setq returnString (vla-GetString (vla-get-Utility doc) :vlax-false "Enter text (a space or <enter> terminates input): "))
(alert (strcat "The string entered was '" returnString "'"))
;; Prompt & Input can contain blanks
(setq returnString (vla-GetString (vla-get-Utility doc) :vlax-true "Enter text (<enter> terminates input):"))
;; Prompt & Input can contain blanks, but not an empty string
(setq NoNull 1) ;; Disallow null
(vla-InitializeUserInput (vla-get-Utility doc) NoNull)
(setq returnString (vla-GetString (vla-get-Utility doc) :vlax-true "Enter text (<enter> terminates input): "))
GMT+8, 2026-10-27 04:47
