GetName 方法 (ActiveX)
获取字典中对象的名称(关键字)。 支持的平台:仅限 Windows 返回值 (RetVal)类型:字符串 对象的名称(关键字)。 言论例如,在以下字典中查询对象“Object2”将返回名称“SecondKeyword”: 我的词典 关键字 - 对象 FirstKeyword - 对象 1 SecondKeyword - 对象 2 例子VBA: Sub Example_GetName()
' This example creates a dictionary and adds
' a custom object to that dictionary. It then
' finds the name of the object in the dictionary.
Dim dictObj As AcadDictionary
Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
' Load the ObjectARX application that defines the custom object.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX application.
ThisDrawing.Application.LoadArx "MyARXApp.dll"
' Create the custom object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As AcadObject
keyName = "OBJ1"
className = "CAsdkDictObject"
Set customObj = dictObj.AddObject(keyName, className)
' Find the keyword name of an object in the dictionary
keyName = dictObj.GetName(customObj)
可视化 LISP: (vl-load-com)
(defun c:Example_GetName()
;; This example creates a dictionary and adds
;; a custom object to that dictionary.
(setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
;; Load the ObjectARX application that defines the custom object.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX application.
(vla-LoadArx acadObj "MyARXApp.dll")
;; Create the custom object in the dictionary
(setq keyName "OBJ1")
(setq className "CAsdkDictObject")
(setq customObj (vla-AddObject dictObj keyName className))
;; Find the keyword name of an object in the dictionary
(setq keyName (vla-GetName dictObj customObj))
GMT+8, 2026-10-27 04:51
