GetLoopAt 方法 (ActiveX)
获取给定索引处的填充循环。 支持的平台:仅限 Windows 签名VBA: object.GetLoopAt Index, Loop
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_GetLoopAt()
' This example creates an associative hatch in model space.
' It then finds the objects that make up the first loop of the hatch.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Append the first circle as one inner loop
Dim innerLoop1(0) As AcadEntity
center(0) = 5: center(1) = 4.5: center(2) = 0
radius = 1
Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop1)
' Append the second circle as the other inner loop
Dim innerLoop2(0) As AcadEntity
radius = 0.5
Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop2)
' Evaluate and display the hatch
hatchObj.Evaluate
ThisDrawing.Regen True
' Find the objects that make up the first loop
Dim loopObjs As Variant
hatchObj.GetLoopAt 0, loopObjs
' Find the types of the objects in the loop
Dim I As Integer
Dim objName As String
objName = ""
For I = LBound(loopObjs) To UBound(loopObjs)
objName = objName & loopObjs(I).EntityName & ", "
Next
MsgBox "The objects in the first loop of the hatch are: " & objName, , "GetLoopAt Example"
可视化 LISP: (vl-load-com)
(defun c:Example_GetLoopAt()
;; This example creates an associative hatch in model space.
;; It then finds the objects that make up the first loop of the hatch.
;; Define the hatch
(setq patternName "ANSI31"
patternType acHatchPatternTypePreDefined
bAssociativity :vlax-true)
;; Create the associative Hatch object
(setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
;; Create the outer loop for the hatch.
;; An arc and a line are used to create a closed loop.
(setq center (vlax-3d-point 5 3 0)
radius 3
startAngle 0
endAngle 3.141592)
(setq arcObj (vla-AddArc modelSpace center radius startAngle endAngle))
(setq lineObj (vla-AddLine modelSpace (vla-get-StartPoint arcObj) (vla-get-EndPoint arcObj)))
(setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element outerLoop 0 arcObj)
(vlax-safearray-put-element outerLoop 1 lineObj)
;; Append the outer loop to the hatch object
(vla-AppendOuterLoop hatchObj outerLoop)
;; Append the first circle as one inner loop
(setq center (vlax-3d-point 5 4.5 0)
radius 1)
(setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop1 0 (vla-AddCircle modelSpace center radius))
(vla-AppendInnerLoop hatchObj innerLoop1)
;; Append the second circle as the other inner loop
(setq radius 0.5)
(setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop2 0 (vla-AddCircle modelSpace center radius))
(vla-AppendInnerLoop hatchObj innerLoop2)
;; Evaluate and display the hatch
(vla-Evaluate hatchObj)
(vla-Regen doc :vlax-true)
;; Find the objects that make up the first loop
(vla-GetLoopAt hatchObj 0 'loopObjs)
;; Find the types of the objects in the loop
(setq I 0
objName "")
(while (>= (vlax-safearray-get-u-bound loopObjs 1) I)
(setq objName (strcat objName (vla-get-ObjectName (vlax-safearray-get-element loopObjs I)) ", "))
(setq I (1+ I))
(alert (strcat "The objects in the first loop of the hatch are: " objName))
GMT+8, 2026-10-27 04:52
