GetGridVisibility 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 777| 评论: 0|原作者: admin|来自: AutoCAD
返回指定网格线型和行类型的网格可见性值。
RetVal = object.GetGridVisibility(gridLineType, rowType)
类型:Table、TableStyle
此方法应用到的对象。
网格线型
访问:仅输入
类型:枚举AcGridLineType
要检查的网格线类型。
  • acHorzBottom:顶部或底部水平网格线,基于流向。
  • acHorzInside:所有水平网格线,不包括顶线和底线。
  • acHorzTop:顶部或底部水平网格线,基于流向。
  • acInvalidGridLine:无效的网格线。
  • acVertInside:所有垂直网格线,不包括最左边和最右边的网格线。
  • acVertLeft:最左边的网格线。
  • acVertRight:最右边的网格线。
行类型
访问:仅输入
类型:枚举AcRowType
行类型。
  • acDataRow
  • acHeaderRow
  • acTitleRow
  • acUnknownRow
返回值 (RetVal)
类型:布尔
  • True:网格线型对于行类型可见。
  • False:网格线型对于行类型不可见。
Sub Example_GetGridVisibility()
    ' the style name and other attributes.
    Dim dictObj As AcadDictionary
    ' Get the current TableStyle object
    Dim tableStyle As AcadTableStyle
    Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE"))
    Dim colGridCurrent As AcadAcCmColor, lwGridCurrent As ACAD_LWEIGHT, visGridCurrent As Boolean
    Set colGridCurrent = tableStyle.GetGridColor(acHorzBottom, acTitleRow)
    lwGridCurrent = tableStyle.GetGridLineWeight(acHorzBottom, acTitleRow)
    visGridCurrent = tableStyle.GetGridVisibility(acHorzTop, acTitleRow)
    MsgBox "Grid settings " & vbLf & _
           "nColor (Bottom) = " & colGridCurrent.ColorIndex & vbLf & _
           "nLineweight (Bottom) = " & lwGridCurrent & vbLf & _
           "Visibility (Top) =  " & visGridCurrent
    Dim col As AcadAcCmColor
    Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(CStr(AcadApplication.Version), 2))
    col.SetRGB 0, 0, 255
    tableStyle.SetGridColor acHorzBottom, acTitleRow, col
    tableStyle.SetGridLineWeight acHorzBottom, acTitleRow, acLnWt025
    If visGridCurrent = False Then
        tableStyle.SetGridVisibility acHorzTop, acTitleRow, True
    Else
        tableStyle.SetGridVisibility acHorzTop, acTitleRow, False
    End If
    Dim colGridNew As AcadAcCmColor, lwGridNew As ACAD_LWEIGHT, visGridNew As Boolean
    Set colGridNew = tableStyle.GetGridColor(acHorzBottom, acTitleRow)
    lwGridNew = tableStyle.GetGridLineWeight(acHorzBottom, acTitleRow)
    visGridNew = tableStyle.GetGridVisibility(acHorzTop, acTitleRow)
           "nColor (Bottom) = " & colGridNew.ColorIndex & vbLf & _
           "nLineweight (Bottom) = " & lwGridNew & vbLf & _
           "Visibility (Top) =  " & visGridNew
    tableStyle.SetGridColor acHorzBottom, acTitleRow, colGridCurrent
    tableStyle.SetGridLineWeight acHorzBottom, acTitleRow, lwGridCurrent
    tableStyle.SetGridVisibility acHorzTop, acTitleRow, visGridCurrent
    MsgBox "Reset the table style back to its original values."
(defun c:Example_GetGridVisibility()
    ;; the style name and other attributes.
    (setq dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Get the current TableStyle object
    (setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE")))
    (setq colGridCurrent (vla-GetGridColor tableStyle acHorzBottom acTitleRow))
    (setq lwGridCurrent (vla-GetGridLineWeight tableStyle acHorzBottom acTitleRow))
    (setq visGridCurrent (vla-GetGridVisibility tableStyle acHorzTop acTitleRow))
    (alert (strcat "Grid settings"
		                 "\nColor (Bottom) = " (itoa (vla-get-ColorIndex colGridCurrent))
		                 "\nLineweight (Bottom) = " (itoa lwGridCurrent)
		                 "\nVisibility (Top)= " (if (= visGridCurrent :vlax-true) "True" "False")))
    (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB col 0 0 255)
    (vla-SetGridColor tableStyle acHorzBottom acTitleRow col)
    (vla-SetGridLineWeight tableStyle acHorzBottom acTitleRow acLnWt025)
    (vla-SetGridVisibility tableStyle acHorzTop acTitleRow (if (= visGridCurrent :vlax-true) :vlax-false :vlax-true))
    (setq colGridNew (vla-GetGridColor tableStyle acHorzBottom acTitleRow))
    (setq lwGridNew (vla-GetGridLineWeight tableStyle acHorzBottom acTitleRow))
    (setq visGridNew (vla-GetGridVisibility tableStyle acHorzTop acTitleRow))
		                 "\nColor (Bottom) = " (itoa (vla-get-ColorIndex colGridNew))
		                 "\nLineweight (Bottom) = " (itoa lwGridNew)
		                 "\nVisibility (Top)= " (if (= visGridNew :vlax-true) "True" "False")))
    (vla-SetGridColor tableStyle acHorzBottom acTitleRow colGridCurrent)
    (vla-SetGridLineWeight tableStyle acHorzBottom acTitleRow lwGridCurrent)
    (vla-SetGridVisibility tableStyle acHorzBottom acTitleRow visGridCurrent)
    (alert "Reset the table style back to its original values.")
    (vlax-release-object col)
GMT+8, 2026-11-15 12:50
