GetGridSpacing 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 829| 评论: 0|原作者: admin|来自: AutoCAD
获取视口的网格间距。
object.GetGridSpacing XSpacing, YSpacing
类型:PViewport、视口
此方法应用到的对象。
XS间距
访问:仅输出
类型:双
视口中网格的 X 间距。
YS间距
访问:仅输出
类型:双
视口中网格的 Y 间距。
返回值 (RetVal)
无返回值。
Sub Example_GetGridSpacing()
    ' This example turns on the grid for the current viewport.
    ' It then finds the current grid spacing, and changes that spacing.
    ' Find the current active viewport
    Dim viewportObj As AcadViewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Turn on the grid and reset the viewport to see it come on.
    viewportObj.GridOn = True
    ThisDrawing.ActiveViewport = viewportObj
    ' Find the current grid spacing
    Dim XSpacing As Double
    Dim YSpacing As Double
    viewportObj.GetGridSpacing XSpacing, YSpacing
    MsgBox "X =" & XSpacing & ", Y =" & YSpacing, , "GetGridSpacing Example"
    ' Change the grid spacing
    XSpacing = XSpacing * 0.5
    YSpacing = YSpacing * 0.5
    viewportObj.SetGridSpacing XSpacing, YSpacing
(defun c:Example_GetGridSpacing()
    ;; This example turns on the grid for the current viewport.
    ;; It then finds the current grid spacing, and changes that spacing.
    ;; Find the current active viewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Turn on the grid and reset the viewport to see it come on.
    (vla-put-GridOn viewportObj :vlax-true)
    (vla-put-ActiveViewport doc viewportObj)
    ;; Find the current grid spacing
    (vla-GetGridSpacing viewportObj 'XSpacing 'YSpacing)
    (alert (strcat "X =" (rtos XSpacing 2) ", Y =" (rtos YSpacing 2)))
    ;; Change the grid spacing
    (vla-SetGridSpacing viewportObj (* XSpacing 0.5) (* YSpacing 0.5))
GMT+8, 2026-10-27 11:08
