GetConstantAttributes 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 850| 评论: 0|原作者: admin|来自: AutoCAD
获取块或外部引用中的常量属性。
RetVal = object.GetConstantAttributes
类型:BlockReference、ExternalReference、MInsertBlock
此方法应用到的对象。
返回值 (RetVal)
类型:Variant(Attribute 对象数组)
块引用的常量对象数组。Attribute
此方法返回附加到模块或外部引用的常量属性数组。返回的属性是常量属性定义,而不是属性引用。
Sub Example_GetConstantAttributes()
    ' This example creates a constant attribute definition on a block.
    ' It then queries the block to return the attribute.
    ' Create the block to hold the attribute
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "New_Block")
    ' Define the attribute definition
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeConstant
    prompt = "Constant Prompt"
    insertionPnt(0) = 5#: insertionPnt(1) = 5#: insertionPnt(2) = 0#
    tag = "Constant_Tag"
    value = "Constant Value"
    ' Create the attribute definition object on the block
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPnt, tag, value)
    ZoomAll
    ' Insert the block into the drawing
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "New_Block", 1#, 1#, 1#, 0)
    ' Get the constant attribute definition from the block
    Dim queryAttribute As Variant
    queryAttribute = blockRefObj.GetConstantAttributes
    Dim count As Integer
    count = UBound(queryAttribute) - LBound(queryAttribute)
    MsgBox "The block reference has " & count & " constant attributes."
(defun c:Example_GetConstantAttributes()
    ;; This example creates a constant attribute definition on a block.
    ;; It then queries the block to return the attribute.
    ;; Create the block to hold the attribute
    (setq insertionPnt (vlax-3d-point 0 0 0))
    (setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "New_Block"))
    ;; Define the attribute definition
    (setq insertionPnt (vlax-3d-point 5 5 0)
          attHeight 1
          attMode acAttributeModeConstant
          attPrompt "Constant Prompt"
          attTag "Constant_Tag"
          attValue "Constant Value")
    ;; Create the attribute definition object on the block
    (setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPnt attTag attValue))
    ;; Insert the block into the drawing
    (setq insertionPnt (vlax-3d-point 2 2 0))
    (setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "New_Block" 1 1 1 0))
    (vla-ZoomAll acadObj)
    ;; Get the constant attribute definition from the block
    (setq queryAttribute (vlax-variant-value (vla-GetConstantAttributes blockRefObj)))
    (setq count (1+ (vlax-safearray-get-u-bound queryAttribute 1)))
    (alert (strcat "The block reference has " (itoa count) " constant attributes."))
GMT+8, 2026-10-27 01:21
