您可以冻结图层以加快显示更改速度、提高对象选择性能并缩短复杂图形的再生时间。AutoCAD 不会在冻结图层上显示、打印或重新生成对象。冻结您不会长时间使用的图层。“解冻”冻结图层时,AutoCAD 将重新生成并显示该图层上的对象。 使用该属性冻结或解冻图层。如果输入值 ,则图层将被冻结。如果输入值 ,则图层将解冻。IsFrozenTRUEFALSE 冻结图层本示例创建一个名为“ABC”的新图层,然后冻结该图层。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("FreezeLayer")> _
Public Sub FreezeLayer()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
Dim sLayerName As String = "ABC"
If acLyrTbl.Has(sLayerName) = False Then
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
'' Assign the layer a name
acLyrTblRec.Name = sLayerName
'' Freeze the layer
acLyrTblRec.IsFrozen = True
'' Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
Else
Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
OpenMode.ForWrite)
'' Freeze the layer
End If
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("FreezeLayer")]
public static void FreezeLayer()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
string sLayerName = "ABC";
if (acLyrTbl.Has(sLayerName) == false)
using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
// Assign the layer a name
acLyrTblRec.Name = sLayerName;
// Freeze the layer
acLyrTblRec.IsFrozen = true;
// Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
// Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec);
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
else
LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
OpenMode.ForWrite) as LayerTableRecord;
// Freeze the layer
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub FreezeLayer()
' Create a new layer called "ABC"
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("ABC")
' Freeze layer "ABC"
layerObj.Freeze = True
相关概念父主题: |
GMT+8, 2026-10-27 05:26
