GetColumnName 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 515| 评论: 0|原作者: admin|来自: AutoCAD
获取列的名称。
RetVal = object.GetColumnName(nIndex)
类型: 表格
此方法应用到的对象。
n索引
访问:仅输入
类型:
列的索引。
返回值 (RetVal)
类型:字符串
列的名称。
Sub Example_ColumnName()
     ' This example adds a table in model space and sets and gets a column name
    Dim MyModelSpace As AcadModelSpace
    Set MyModelSpace = ThisDrawing.ModelSpace
    Dim pt(2) As Double
    Dim MyTable As AcadTable
    Dim cName As String
    Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
    Call MyTable.SetColumnName(2, "Test Name")
    MsgBox "The column name is: " & vbCrLf & _
           MyTable.GetColumnName(2)
    ZoomExtents
(defun c:Example_ColumnName()
    ;; This example adds a table in model space and sets and gets a column name
    (setq pt (vlax-3d-point 0 0 0))
    (setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
    (vla-SetColumnName MyTable 2 "Test Name")
    (alert (strcat "The column name is: \n"
                   (vla-GetColumnName MyTable 2)))
    (vla-ZoomExtents acadObj)
GMT+8, 2026-9-16 14:38
