GetCellClass 方法 (ActiveX)
获取单元格样式的类。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetCellClass(StringCellStyle)
返回值 (RetVal)类型:整数 单元格样式类。 言论没有其他评论。 例子VBA: Sub Example_CellClass()
' the style classes and formatting.
Dim dictObj As AcadDictionary
' Create the custom TableStyle object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As IAcadTableStyle
keyName = "NewStyle"
className = "AcDbTableStyle"
Set customObj = dictObj.AddObject(keyName, className)
customObj.Name = "NewStyle"
customObj.Description = "New Style for My Tables"
customObj.CreateCellStyle ("NewTestStyle")
Dim cellTestFormat As String
customObj.SetCellClass "NewTestStyle", 4
customObj.SetRotation "NewTestStyle", 8.4
MsgBox "The cell class is " & customObj.GetCellClass("NewTestStyle") & _
" the cell rotation is " & customObj.GetRotation("NewTestStyle")
可视化 LISP: (vl-load-com)
(defun c:Example_CellClass()
;; the style classes and formatting.
(setq dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Create the custom TableStyle object in the dictionary
(setq keyName "NewStyle"
className "AcDbTableStyle")
(setq customObj (vla-AddObject dictObj keyName className))
(vla-put-Name customObj "NewStyle")
(vla-put-Description customObj "New Style for My Tables")
(vla-CreateCellStyle customObj "NewTestStyle")
(vla-SetCellClass customObj "NewTestStyle" 4)
(vla-SetRotation customObj "NewTestStyle" 8.4)
(alert (strcat "The cell class is " (itoa (vla-GetCellClass customObj "NewTestStyle"))
" and the cell rotation is " (rtos (vla-GetRotation customObj "NewTestStyle") 2) "."
GMT+8, 2026-11-3 18:35
