GetBulge 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 911| 评论: 0|原作者: admin|来自: AutoCAD
获取折线的给定索引处的凸起值。
RetVal = object.GetBulge(Index)
类型:LWPolyline,折线
此方法应用到的对象。
指数
访问:仅输入
类型:整数
要查询的顶点的索引位置。索引必须是以零开头的正整数。
返回值 (RetVal)
类型:双
给定索引处顶点的凸起值。
折线:如果折线属性不是 。TypeacSimplePoly
凸起是所选顶点与折线顶点列表中的下一个顶点之间的弧所包含角度的 1/4 的切线。负凸起值表示圆弧从所选顶点顺时针方向移动到下一个顶点。凸起 0 表示直线段,凸起 1 表示半圆。
Sub Example_GetBulge()
    ' This example creates a lightweight polyline in model space.
    ' It then finds and changes the bulge for a given segment.
    Dim points(0 To 11) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 1
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ZoomAll
    ' Find the bulge of the third segment
    Dim currentBulge As Double
    currentBulge = plineObj.GetBulge(3)
    MsgBox "The bulge for the third segment is " & plineObj.GetBulge(3), , "GetBulge Example"
    ' Change the bulge of the third segment
    plineObj.SetBulge 3, -0.5
    plineObj.Update
    MsgBox "The bulge for the third segment is now " & plineObj.GetBulge(3), , "GetBulge Example"
(defun c:Example_GetBulge()
    ;; This example creates a lightweight polyline in model space.
    ;; It then finds and changes the bulge for a given segment.
    ;; Define the 2D polyline points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
    (vlax-safearray-fill points '(1 1
                                  1 2
                                  2 2
                                  3 2
                                  4 4
                                  4 1
    ;; Create a lightweight Polyline object in model space
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-ZoomAll acadObj)
    ;; Find the bulge of the third segment
    (setq currentBulge (vla-GetBulge plineObj 3))
    (alert (strcat "The bulge for the third segment is " (rtos (vla-GetBulge plineObj 3) 2)))
    ;; Change the bulge of the third segment
    (vla-SetBulge plineObj 3 -0.5)
    (vla-Update plineObj)
    (alert (strcat "The bulge for the third segment is now " (rtos (vla-GetBulge plineObj 3) 2)))
GMT+8, 2026-10-27 01:21
