GetBreakHeight 方法 (ActiveX)
获取工作台的断裂高度。 支持的平台:仅限 Windows 返回值 (RetVal)类型:双 中断的高度值。 言论没有其他评论。 例子VBA: Sub Example_BreakHeight()
' This example creates a table object and then breaks it into
' two tables.
' Create a new table object in model space
Dim pt(2) As Double
Dim modelSpace As AcadModelSpace
Set modelSpace = ThisDrawing.modelSpace
Dim table As AcadTable
Set table = modelSpace.AddTable(pt, 5, 5, 10, 30)
table.EnableBreak = True
table.BreakSpacing = 3.5
table.TableBreakHeight = 35#
table.AllowManualHeights = True
table.SetBreakHeight 0, 20#
table.SetBreakHeight 1, 35#
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_BreakHeight()
;; This example creates a table object and then breaks it into
;; two tables.
;; Create a new table object in model space
(setq pt (vlax-3d-point 0 0 0))
(setq table (vla-Addtable modelSpace pt 5 5 10 30))
(vla-put-EnableBreak table :vlax-true)
(vla-put-BreakSpacing table 3.5)
(vla-put-TableBreakHeight table 35.0)
(vla-put-AllowManualHeights table :vlax-true)
(vla-SetBreakHeight table 0 20.0)
(vla-SetBreakHeight table 1 35.0)
(vla-ZoomExtents acadObj)
GMT+8, 2026-10-27 04:55
