GetBoundingBox 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 651| 评论: 0|原作者: admin|来自: AutoCAD
获取包含指定对象的框的两个点。
object.GetBoundingBox MinPoint, MaxPoint
类型:所有绘图对象、AttributeReference、尺寸
此方法应用到的对象。
闵点
访问:仅输出
类型:变体(双打的三元素阵列)
指定对象边界框最小点的 3D WCS 坐标。
马克斯波因特
访问:仅输出
类型:变体(双打的三元素阵列)
指定对象边界框最大点的 3D WCS 坐标。
返回值 (RetVal)
无返回值。
拐角以 WCS 坐标返回,框边平行于 WCS X、Y 和 Z 轴。
Sub Example_GetBoundingBox()
    ' This example creates a line in model space. It then finds the
    ' bounding box for the line and displays the corners of the box.
    Dim lineObj As AcadLine
    ' Create the Line object in model space
    startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
    endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
    ZoomAll
    Dim minExt As Variant
    Dim maxExt As Variant
    ' Return the bounding box for the line and return the minimum
    ' and maximum extents of the box in the minExt and maxExt variables.
    lineObj.GetBoundingBox minExt, maxExt
    ' Print the min and max extents
    MsgBox "The extents of the bounding box for the line are:" & vbCrLf _
         & "Min Extent: " & minExt(0) & "," & minExt(1) & "," & minExt(2) _
         & vbCrLf & "Max Extent: " & maxExt(0) & "," & maxExt(1) & "," & maxExt(2), vbInformation, "GetBoundingBox Example"
(defun c:Example_GetBoundingBox()
    ;; This example creates a line in model space. It then finds the
    ;; bounding box for the line and displays the corners of the box.
    ;; Create the Line object in model space
    (setq startPoint (vlax-3D-point 2 2 0))
    (setq endPoint (vlax-3D-point 4 4 0))
    (vla-ZoomAll acadObj)
    ;; Return the bounding box for the line and return the minimum
    ;; and maximum extents of the box in the minExt and maxExt variables.
    (vla-GetBoundingBox lineObj 'minExt 'maxExt)
    (setq minExt (vlax-safearray->list minExt)
	         maxExt (vlax-safearray->list maxExt))
    ;; Print the min and max extents
    (alert (strcat "The extents of the bounding box for the line are:"
                   "\nMin Extent: " (rtos (nth 0 minExt) 2) "," (rtos (nth 1 minExt) 2) "," (rtos (nth 2 minExt) 2)
                   "\nMax Extent: " (rtos (nth 0 maxExt) 2) "," (rtos (nth 1 maxExt) 2) "," (rtos (nth 2 maxExt) 2)))
GMT+8, 2026-11-15 11:39
