GetAttributes 方法 (ActiveX)
获取块引用中的属性。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetAttributes
言论此方法返回附加到块引用的可编辑属性引用数组。 您只能返回外部参照的常量属性。若要查找外部引用或块引用的常量属性,请使用该方法。GetConstantAttributes 例子VBA: Sub Example_GetAttributes()
' This example creates a block. It then adds attributes to that
' block. The block is then inserted into the drawing to create
' a block reference.
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "TESTBLOCK")
' Define the attribute definition
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
height = 1#
mode = acAttributeModeVerify
prompt = "Attribute Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "Attribute_Tag"
value = "Attribute Value"
' Create the attribute definition object in model space
Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TESTBLOCK", 1#, 1#, 1#, 0)
ZoomAll
' Get the attributes for the block reference
Dim varAttributes As Variant
varAttributes = blockRefObj.GetAttributes
' Move the attribute tags and values into a string to be displayed in a Msgbox
Dim strAttributes As String
Dim I As Integer
For I = LBound(varAttributes) To UBound(varAttributes)
strAttributes = strAttributes & vbLf & " Tag: " & varAttributes(I).TagString & _
vbLf & " Value: " & varAttributes(I).TextString & vbLf & " "
Next
MsgBox "The attributes for blockReference " & blockRefObj.Name & " are: " & strAttributes, , "GetAttributes Example"
' Change the value of the attribute
' Note: There is no SetAttributes. Once you have the variant array, you have the objects.
' Changing them changes the objects in the drawing.
varAttributes(0).TextString = "NEW VALUE!"
Dim newvarAttributes As Variant
newvarAttributes = blockRefObj.GetAttributes
' Again, display the tags and values
strAttributes = ""
Next
可视化 LISP: (vl-load-com)
(defun c:Example_GetAttributes()
;; This example creates a block. It then adds attributes to that
;; block. The block is then inserted into the drawing to create
;; a block reference.
;; Create the block
(setq insertionPnt (vlax-3d-point 0 0 0))
(setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "TESTBLOCK"))
;; Define the attribute definition
(setq attHeight 1
attMode acAttributeModeVerify
attPrompt "Attribute Prompt"
attTag "Attribute_Tag"
attValue "Attribute Value"
insertionPoint (vlax-3d-point 5 5 0))
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPoint attTag attValue))
;; Insert the block
(setq insertionPnt (vlax-3d-point 2 2 0))
(setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "TESTBLOCK" 1 1 1 0))
(vla-ZoomAll acadObj)
;; Get the attributes for the block reference
(setq varAttributes (vlax-variant-value (vla-GetAttributes blockRefObj)))
;; Move the attribute tags and values into a string to be displayed in a Msgbox
(setq strAttributes ""
I 0)
(while (>= (vlax-safearray-get-u-bound varAttributes 1) I)
(setq strAttributes (strcat strAttributes "\n Tag: " (vla-get-TagString (vlax-safearray-get-element varAttributes I))
"\n Value: " (vla-get-TextString (vlax-safearray-get-element varAttributes I)) "\n"))
(setq I (1+ I))
(alert (strcat "The attributes for blockReference " (vla-get-Name blockRefObj) " are: " strAttributes))
;; Change the value of the attribute
;; Note: There is no SetAttributes. Once you have the variant array, you have the objects.
;; Changing them changes the objects in the drawing.
(vla-put-TextString (vlax-safearray-get-element varAttributes 0) "NEW VALUE!")
(setq newvarAttributes (vlax-variant-value (vla-GetAttributes blockRefObj)))
;; Again, display the tags and values
I 0)
(setq I (1+ I))
GMT+8, 2026-11-15 11:49
