GetAllProfileNames 方法 (ActiveX)
获取系统的所有可用配置文件。 支持的平台:仅限 Windows 签名VBA: object.GetAllProfileNames pNames
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_GetAllProfileNames()
' This example gets all the profiles available for the system.
Dim systemProfiles As Variant
AcadApplication.Preferences.Profiles.GetAllProfileNames systemProfiles
' List all the profiles for the system
Dim x As Integer
Dim msg As String
msg = ""
For x = LBound(systemProfiles) To UBound(systemProfiles)
msg = msg & systemProfiles(x) & vbCrLf
Next
MsgBox msg, vbInformation, "Available Profiles"
可视化 LISP: (vl-load-com)
(defun c:Example_GetAllProfileNames()
;; This example gets all the profiles available for the system.
;; Use the PreferencesProfiles object
(setq systemProfiles "")
(vla-GetAllProfileNames (vla-get-Profiles preferences) 'systemProfiles)
;; List all the profiles for the system
(setq x 0
msg "")
(while (>= (vlax-safearray-get-u-bound systemProfiles 1) x)
(setq msg (strcat msg (vlax-safearray-get-element systemProfiles x) "\n"))
(setq x (1+ x))
(alert msg)
GMT+8, 2026-10-28 10:50
