FieldCode 方法 (ActiveX)
返回包含域代码的文本字符串。 支持的平台:仅限 Windows 返回值 (RetVal)类型:字符串 对象的域代码。 言论没有其他评论。 例子VBA: Sub Example_FieldCode()
' This example creates a text object in model space.
' It then returns the field code string for the object.
Dim textObj As AcadText
Dim text As String
Dim height As Double
' Define the text object
text = "%<\AcVar Date \f ""M/d/yyyy""%>%"
insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(text, insertionPoint, height)
ZoomAll
' Return the current text string for the object
text = textObj.FieldCode
MsgBox "The FieldCode for the text object equals: " & text, vbInformation, "FieldCode Example"
可视化 LISP: (vl-load-com)
(defun c:Example_FieldCode()
;; This example creates a text object in model space.
;; It then returns the field code string for the object.
;; Define the text object
(setq insertionPoint (vlax-3d-point 2 2 0)
text "%<\\AcVar Date \\f \"M/d/yyyy\"%>%"
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace text insertionPoint height))
(vla-ZoomAll acadObj)
;; Return the current text string for the object
(setq text (vla-FieldCode textObj))
(alert (strcat "The FieldCode for the text object equals: " text))
GMT+8, 2026-10-28 03:56
