ElevateOrder 方法 (ActiveX)
将样条曲线的顺序提升到给定顺序。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论样条曲线的阶数等于样条曲线的阶数加一 (+1)。可以使用属性查询样条的度数。Degree 输入大于当前值的值会均匀地增加样条曲线上的控制点数,以实现更局部的控制。样条阶一旦提升,就不能减少。 当样条曲线被抬高时,该样条曲线将从插值(拟合)样条转换为控制点样条曲线。这意味着在高程之后,样条不再具有拟合切线,并且样条的 和 属性不再可用。编辑控制点样条曲线的唯一方法是通过属性或 or 方法。StartTangentEndTangentControlPointsSetControlPointGetControlPoint 例子VBA: Sub Example_ElevateOrder()
' This example creates a spline object in model space.
' It then elevates the order of the spline.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
MsgBox "The current order of the spline is " & splineObj.Degree + 1, , "ElevateOrder Example"
' Elevate the order of the spline
splineObj.ElevateOrder (splineObj.Degree + 10)
ThisDrawing.Regen True
MsgBox "The order of the spline has been raised to " & splineObj.Degree + 1, , "ElevateOrder Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ElevateOrder()
;; This example creates a spline object in model space.
;; It then elevates the order of the spline.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
(alert (strcat "The current order of the spline is " (itoa (1+ (vla-get-Degree splineObj)))))
;; Elevate the order of the spline
(vla-ElevateOrder splineObj (+ (vla-get-Degree splineObj) 10))
(vla-Regen doc :vlax-true)
(alert (strcat "The order of the spline has been raised to " (itoa (1+ (vla-get-Degree splineObj)))))
GMT+8, 2026-10-27 04:53
