DistanceToReal 方法 (ActiveX)
将字符串的距离转换为实数(双精度)值。 支持的平台:仅限 Windows 签名VBA: RetVal = DistanceToReal(Distance, Unit)
返回值 (RetVal)类型:双 以实数表示的距离。 言论没有其他评论。 例子VBA: Sub Example_DistanceToReal()
' This example passes several different distances in
' different units to be converted to real values.
Dim distAsString As String
Dim unit As Long
Dim distAsReal As Double
' Convert the distance to a real in scientific units
unit = acScientific
distAsString = "1.75E+01"
distAsReal = ThisDrawing.Utility.DistanceToReal(distAsString, unit)
MsgBox "1.75E+01 converts to " & distAsReal & " in scientific units.", , "DistanceToReal Example"
' Convert the distance to a real in decimal units
unit = acDecimal
distAsString = "17.5"
MsgBox "1.75 converts to " & distAsReal & " in decimal units.", , "DistanceToReal Example"
' Convert the distance to a real in engineering units
unit = acEngineering
distAsString = "1'-5.50"""
MsgBox "1'-5.50"" converts to " & distAsReal & " in engineering units.", , "DistanceToReal Example"
' Convert the distance to a real in architectural units
unit = acArchitectural
distAsString = "1'-5 1/2"""
MsgBox "1'-5 1/2"" converts to " & distAsReal & " in architectural units.", , "DistanceToReal Example"
' Convert the distance to a real in fractional units
unit = acFractional
distAsString = "17 1/2"
MsgBox "1'-5 1/2"" converts to " & distAsReal & " in fractional units.", , "DistanceToReal Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DistanceToReal()
;; This example passes several different distances in
;; different units to be converted to real values.
;; Convert the distance to a real in scientific units
(setq unit acScientific
distAsString "1.75E+01"
distAsReal (vla-DistanceToReal (vla-get-Utility doc) distAsString unit))
(alert (strcat "1.75E+01 converts to " (rtos distAsReal 2) " in scientific units."))
;; Convert the distance to a real in decimal units
(setq unit acDecimal
distAsString "17.5"
(alert (strcat "17.5 converts to " (rtos distAsReal 2) " in decimal units."))
;; Convert the distance to a real in engineering units
(setq unit acEngineering
distAsString "1'-5.50\""
(alert (strcat "1'-5.50\" converts to " (rtos distAsReal 2) " in engineering units."))
;; Convert the distance to a real in architectural units
(setq unit acArchitectural
distAsString "1'-5 1/2\""
(alert (strcat "1'-5 1/2\" converts to " (rtos distAsReal 2) " in architectural units."))
;; Convert the distance to a real in fractional units
(setq unit acFractional
distAsString "17 1/2"
(alert (strcat "17 1/2 converts to " (rtos distAsReal 2) " in fractional units."))
GMT+8, 2026-10-27 09:47
