Detach 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 838| 评论: 0|原作者: admin|来自: AutoCAD
Detach 方法 (ActiveX)
从绘图中分离外部参照 (外部参照)。
object.Detach
类型:块
此方法应用到的对象。
返回值 (RetVal)
无返回值。
分离外部参照会从当前图形中移除外部参照。将擦除外部参照的所有副本,并删除外部参照定义。所有与外部参照相关的符号表信息(如图层和线型)都将从当前图形中删除。
不能分离包含其他外部参照的外部参照。
Sub Example_Detach()
    On Error GoTo ERRORHANDLER
    ' Define external reference to be inserted
    Dim xrefHome As AcadBlock
    Dim xrefInserted As AcadExternalReference
    Dim insertionPnt(0 To 2) As Double
    Dim PathName As String
    insertionPnt(0) = 1
    insertionPnt(1) = 1
    insertionPnt(2) = 0
    PathName = "c:/AutoCAD/sample/City map.dwg"
    ' Add the external reference
    Set xrefInserted = ThisDrawing.ModelSpace. _
            AttachExternalReference(PathName, "XREF_IMAGE", _
            insertionPnt, 1, 1, 1, 0, False)
    ZoomAll
    MsgBox "The external reference is attached."
    ' Detach the external reference definition
    Dim name As String
    name = xrefInserted.name
    ThisDrawing.Blocks.Item(name).Detach
    MsgBox "The external reference is detached."
    Exit Sub
ERRORHANDLER:
    MsgBox Err.Description
(defun c:Example_Detach()
    ;; Define external reference to be inserted
    (setq insertionPnt (vlax-3d-point 1 1 0)
          pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
    ;; Add the external reference
    (setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
    (vla-ZoomAll acadObj)
    (alert "The external reference is attached.")
    ;; Detach the external reference definition
    (setq name (vla-get-Name xrefInserted))
    (vla-Detach (vla-Item (vla-get-Blocks doc) name))
    (alert "The external reference is detached.")
GMT+8, 2026-10-27 09:46
