Copy 方法 (ActiveX)
将给定对象复制到同一位置。 支持的平台:仅限 Windows 言论AttributeReference:不应尝试在对象上使用此方法。 对象继承此方法,因为它们是绘图对象之一,但是,对属性参照执行此操作是不可行的。AttributeReferenceAttributeReference 注意:不能在同时循环访问集合时执行此方法。迭代将为只读操作打开工作空间,而此方法将尝试执行读写操作。在调用此方法之前,请完成任何迭代。
例子VBA: Sub Example_Copy()
' This example creates a circle and then copies
' that circle. The new circle is then moved.
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2#: center(1) = 2#: center(2) = 0#
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ZoomAll
MsgBox "Copy the circle.", , "Copy Example"
' Copy the circle
Dim copyCircleObj As AcadCircle
Set copyCircleObj = circleObj.Copy()
' Define the points that make up the move vector
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
point1(0) = 0: point1(1) = 0: point1(2) = 0
point2(0) = 2: point2(1) = 0: point2(2) = 0
MsgBox "Move the copied circle 2 units in the X direction.", , "Copy Example"
' Move the circle and color it
copyCircleObj.Move point1, point2
ZoomAll
MsgBox "Move completed.", , "Copy Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Copy()
;; This example creates a circle and then copies
;; that circle. The new circle is then moved.
;; Create the circle
(setq center (vlax-3d-point 2 2 0)
radius 0.5)
(setq circleObj (vla-AddCircle modelSpace center radius))
(vla-ZoomAll acadObj)
(alert "Copy the circle.")
;; Copy the circle
(setq copyCircleObj (vla-Copy circleObj))
;; Define the points that make up the move vector
(setq point1 (vlax-3d-point 0 0 0)
point2 (vlax-3d-point 2 0 0))
(alert "Move the copied circle 2 units in the X direction.")
;; Move the circle and color it
(vla-Move copyCircleObj point1 point2)
(alert "Move completed.")
GMT+8, 2026-10-27 08:59
