AttachToolbarToFlyout 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 859| 评论: 0|原作者: admin|来自: AutoCAD
将工具栏附加到定义为浮出控件的工具栏按钮。
object.AttachToolbarToFlyout MenuGroupName, ToolbarName
类型:ToolbarItem
此方法应用到的对象。
MenuGroup名称
访问:仅输入
类型:字符串
包含要附加的工具栏的菜单组的名称。
工具栏名称
访问:仅输入
类型:字符串
要附加的工具栏的名称。
返回值 (RetVal)
无返回值。
若要将新按钮创建为浮出控件,请使用该方法并将 FlyoutButton 参数设置为 。将按钮创建为浮出控件按钮后,可以使用该方法将浮出控件工具栏附加到该按钮。AddToolBarButtonTrueAttachToolbarToFlyout
若要查询工具栏按钮以查看它是否为浮出控件按钮,请使用该属性。若要查找附加到浮出控件工具栏按钮的工具栏,请使用该属性。TypeFlyout
Sub Example_AttachToolbarToFlyout()
    ' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ' It then creates a new Toolbar(TestMenu) with a Toolbar button that will act
    ' as a flyout.  It then sets the Flyout menu to an existing Toolbar menu.
    ' The Toolbar will automatically be displayed and will display the UCS menu
    ' as a flyout.
    Dim currMenuGroup As acadMenuGroup
    Dim newToolBar As AcadToolbar, newToolBarFlyoutButton As AcadToolbarItem
    On Error GoTo ERRORTRAP
    ' Use MenuGroups property to obtain reference to main AutoCAD menu
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
    ' Create a new Toolbar in this group
    Set newToolBar = currMenuGroup.Toolbars.Add("TestMenu")
    ' Add new button to TestMenu that will link to the Flyout menu
    ' * NOTE: Set the macro name to the name of the flyout toolbar because
    ' setting it to an empty string causes an error.  The paremeter
    ' is actually ignored when the style is flyout, but must have any value other than "".
    Set newToolBarFlyoutButton = newToolBar.AddToolbarButton(newToolBar.count + 1, "Flyout", "Flyout", "UCS", True)
    ' Link the existing toolbar "UCS" as the flyout for the new toolbar button
    ' * NOTE: To change the flyout, simply change the MenuGroup and Toolbar name below
    newToolBarFlyoutButton.AttachToolbarToFlyout "ACAD", "UCS"
    MsgBox "A new Toolbar with a flyout has been added to the AutoCAD menu system!"
    Exit Sub
ERRORTRAP:
    MsgBox "The following error has occurred: " & Err.Description
(defun c:Example_AttachToolbarToFlyout()
    ;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ;; It then creates a new Toolbar(TestMenu) with a Toolbar button that will act
    ;; as a flyout.  It then sets the Flyout menu to an existing Toolbar menu.
    ;; The Toolbar will automatically be displayed and will display the UCS menu
    ;; as a flyout.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create a new Toolbar in this group
    (setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestMenu"))
    ;; Add new button to TestMenu that will link to the Flyout menu
    ;; * NOTE: Set the macro name to the name of the flyout toolbar because
    ;; setting it to an empty string causes an error.  The paremeter
    ;; is actually ignored when the style is flyout, but must have any value other than "".
    (setq newToolBarFlyoutButton (vla-AddToolbarButton newToolBar (1+ (vla-get-Count newToolBar)) "Flyout" "Flyout" "UCS" :vlax-true))
    ;; Link the existing toolbar "UCS" as the flyout for the new toolbar button
    ;; * NOTE: To change the flyout, simply change the MenuGroup and Toolbar name below
    (vla-AttachToolbarToFlyout newToolBarFlyoutButton "ACAD" "UCS")
    (alert "A new Toolbar with a flyout has been added to the AutoCAD menu system!")
GMT+8, 2026-10-27 05:09
