AppendVertex 方法 (ActiveX)
将顶点追加到 3DPolyline、折线或 PolygonMesh 对象的末尾。 支持的平台:仅限 Windows 签名VBA: object.AppendVertex Point
返回值 (RetVal)无返回值。 言论PolygonMesh:将顶点附加到对象的末尾时,将附加一行顶点。例如,对于 4 x 3,您定义了 12 个顶点。附加一个顶点将使矩阵为 5 x 3,因此需要三个额外的坐标。如果 4 x 3 矩阵的最后一个顶点如下:PolygonMeshPolygonMesh
您将附加:
可以使用该方法将对象的 OCS 坐标与其他坐标系相互转换。PolylineTranslateCoordinates 例子VBA: Sub Example_AppendVertex()
' This example creates a polyline in model space.
' It then appends a vertex to the polyline.
Dim plineObj As AcadPolyline
Dim points(0 To 14) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
' Create a lightweight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
ZoomAll
MsgBox "Append the vertex 4, 1, 0.", , "AppendVertex Example"
Dim newVertex(0 To 2) As Double
newVertex(0) = 4: newVertex(1) = 1: newVertex(2) = 0
plineObj.AppendVertex newVertex
ZoomAll
MsgBox "The vertex 4, 1, 0 as been appended.", , "AppendVertex Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AppendVertex()
;; This example creates a polyline in model space.
;; It then appends a vertex to the polyline.
;; Define the 2D polyline points
(setq center (vlax-make-safearray vlax-vbDouble '(0 . 14)))
(vlax-safearray-fill center '(1 1 0
1 2 0
2 2 0
3 2 0
4 4 0
;; Create a lightweight Polyline object in model space
(setq plineObj (vla-AddPolyline modelSpace points))
(vla-ZoomAll acadObj)
(alert "Append the vertex 4, 1, 0.")
(setq newVertex (vlax-3d-point 4 1 0))
(vla-AppendVertex plineObj newVertex)
(alert "The vertex 4, 1, 0 as been appended.")
GMT+8, 2026-10-27 04:32
