AngleToString 方法 (ActiveX)
将角度从实数(双精度)值转换为字符串。 支持的平台:仅限 Windows 签名VBA: RetVal = AngleToString(Angle, Unit, Precision)
返回值 (RetVal)类型:字符串 作为字符串的角度。 言论没有其他评论。 例子VBA: Sub Example_AngleToString()
' This example converts a radian value to several different
' strings representing the value in different units.
Dim angAsRad As Double
Dim unit As Integer
Dim precision As Long
Dim angAsString As String
angAsRad = 0.785398163397448
unit = acDegrees
precision = 6
' Convert the radian value to degrees with a precision of 6
angAsString = ThisDrawing.Utility.AngleToString(angAsRad, unit, precision)
MsgBox "0.785398163397448 radians = " & angAsString & " degrees", , "AngleAsString Example"
' Convert the radian value to degrees/Minutes/Seconds with a precision of 6
unit = acDegreeMinuteSeconds
MsgBox "0.785398163397448 radians = " & angAsString, , "AngleAsString Example"
' Convert the radian value to grads with a precision of 6
unit = acGrads
可视化 LISP: (vl-load-com)
(defun c:Example_AngleToString()
;; This example converts a radian value to several different
;; strings representing the value in different units.
(setq angAsRad 0.785398163397448
unit acDegrees
precision 6)
;; Convert the radian value to degrees with a precision of 6
(setq angAsString (vla-AngleToString (vla-get-Utility doc) angAsRad unit precision))
(alert (strcat "0.785398163397448 radians = " angAsString))
;; Convert the radian value to degrees/Minutes/Seconds with a precision of 6
(setq unit acDegreeMinuteSeconds)
;; Convert the radian value to grads with a precision of 6
(setq unit acGrads)
GMT+8, 2026-10-27 05:45
