AngleToReal 方法 (ActiveX)
将角度转换为字符串,转换为实数(双精度)值。 支持的平台:仅限 Windows 签名VBA: RetVal = AngleToReal(Angle, Unit)
返回值 (RetVal)类型:双 作为实数的角度。 言论没有其他评论。 例子VBA: Sub Example_AngleToReal()
' This example passes several different strings representing
' an angle in different units to be converted to radians.
Dim angAsStr As String
Dim unit As Integer
Dim angAsReal As Double
' Convert the angle given in degrees unit to a real
angAsStr = "45"
unit = acDegrees
angAsReal = ThisDrawing.Utility.AngleToReal(angAsStr, unit)
MsgBox "45 degrees converts to " & angAsReal & " radians.", , "AngleAsReal Example"
' Convert the angle given in degrees/minutes/seconds unit to Radians
angAsStr = "45d0' 0"""
unit = acDegreeMinuteSeconds
MsgBox "45 degrees, 0 minutes, 0 seconds converts to " & angAsReal & " radians.", , "AngleAsReal Example"
' Convert the angle given in grads unit to Radians
angAsStr = "50"
unit = acGrads
MsgBox "50 grads converts to " & angAsReal & " radians.", , "AngleAsReal Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AngleToReal()
;; This example passes several different strings representing
;; an angle in different units to be converted to radians.
;; Convert the angle given in degrees unit to a real
(setq angAsStr "45"
unit acDegrees
angAsReal (vla-AngleToReal (vla-get-Utility doc) angAsStr unit))
(alert (strcat "45 degrees converts to " (rtos angAsReal 2) " radians."))
;; Convert the angle given in degrees/minutes/seconds unit to Radians
(setq angAsStr "45d0' 0\""
unit acDegreeMinuteSeconds
(alert (strcat "45 degrees, 0 minutes, 0 seconds converts to " (rtos angAsReal 2) " radians."))
;; Convert the angle given in grads unit to Radians
(setq angAsStr "50"
unit acGrads
(alert (strcat "50 grads converts to " (rtos angAsReal 2) " radians."))
GMT+8, 2026-11-19 11:49
