AngleFromXAxis 方法 (ActiveX)
获取线与 X 轴的角度。 支持的平台:仅限 Windows 签名VBA: RetVal = AngleFromXAxis(Point1, Point2)
返回值 (RetVal)类型:双 线的角度(以弧度为单位)。 言论没有其他评论。 例子VBA: Sub Example_AngleFromXAxis()
' This example finds the angle, in radians, between the X axis
' and a line defined by two points.
Dim pt1(0 To 2) As Double
Dim pt2(0 To 2) As Double
Dim retAngle As Double
pt1(0) = 2: pt1(1) = 5: pt1(2) = 0
pt2(0) = 5: pt2(1) = 2: pt2(2) = 0
' Return the angle
retAngle = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2)
' Create the line for a visual reference
Dim lineObj As AcadLine
Set lineObj = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
ZoomAll
' Display the angle found
MsgBox "The angle in radians between the X axis and the line is " & retAngle, , "AngleFromXAxis Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AngleFromXAxis()
;; This example finds the angle, in radians, between the X axis
;; and a line defined by two points.
;; Return the angle
(setq pt1 (vlax-3d-point 2 5 0)
pt2 (vlax-3d-point 5 2 0))
(setq retAngle (vla-AngleFromXAxis (vla-get-Utility doc) pt1 pt2))
;; Create the line for a visual reference
(setq lineObj (vla-AddLine modelSpace pt1 pt2))
(vla-ZoomAll acadObj)
;; Display the angle found
(alert (strcat "The angle in radians between the X axis and the line is " (rtos retAngle 2)))
GMT+8, 2026-10-27 14:29
