AddVertex 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 878| 评论: 0|原作者: admin|来自: AutoCAD
将顶点添加到轻量级折线或截面。
object.AddVertex Index, Point
类型:LWPolyline,截面
此方法应用到的对象。
指数
访问:仅输入
类型:长
要添加顶点的顶点数组中的索引。索引必须为正整数。数组的第一个元素是索引 0。
点
访问:仅输入
类型:变体(双打的三元素阵列)
用于创建新顶点的 3D OCS 坐标。
返回值 (RetVal)
无返回值。
LWPolyline:顶点指定新线段的端点。要将弧段添加到轻量级折线,请先创建线段,然后将“凸起”添加到要成为弧的单个线段。若要向区段添加凸起值,请使用该方法。SetBulge
截面:顶点指定截面线上的一个点。
可以使用该方法将坐标转换为 OCS 或从 OCS 转换坐标。TranslateCoordinates
Sub Example_AddVertex()
    ' This example creates a lightweight polyline in model space.
    ' It then adds a vertex to the polyline.
    Dim points(0 To 9) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ZoomAll
    MsgBox "Add a vertex to the end of the polyline.", , "AddVertex Example"
    ' Define the new vertex
    Dim newVertex(0 To 1) As Double
    newVertex(0) = 4: newVertex(1) = 1
    ' Add the vertex to the polyline
    plineObj.AddVertex 5, newVertex
    plineObj.Update
    MsgBox "Vertex added.", , "AddVertex Example"
(defun c:Example_AddVertex()
    ;; This example creates a lightweight polyline in model space.
    ;; It then adds a vertex to the polyline.
    ;; Define the 2D polyline points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 9)))
    (vlax-safearray-fill points '(1 1
                                  1 2
                                  2 2
                                  3 2
                                  4 4
    ;; Create a lightweight Polyline object in model space
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-ZoomAll acadObj)
    (alert "Add a vertex to the end of the polyline.")
    ;; Define the new vertex
    (setq newVertex (vlax-make-safearray vlax-vbDouble '(0 . 1)))
    (vlax-safearray-fill newVertex '(4 1))
    ;; Add the vertex to the polyline
    (vla-AddVertex plineObj 5 newVertex)
    (vla-Update plineObj)
    (alert "Vertex added.")
GMT+8, 2026-10-27 04:14
