AddTolerance 方法 (ActiveX)
创建公差图元。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddTolerance(Text, InsertionPoint, Direction) 言论没有其他评论。 例子VBA: Sub Example_AddTolerance()
' This example creates a tolerance object in model space.
Dim toleranceObj As AcadTolerance
Dim textString As String
Dim direction(0 To 2) As Double
' Define the tolerance object
textString = "{\Fgdt;r}%%vasdf{\Fgdt;l}%%vdf%%vxc%%v12{\Fgdt;m}%%vsd" & vbCrLf & _
"{\Fgdt;t}%%vdfd%%v3dd{\Fgdt;l}%%vv%%v%%vxc{\Fgdt;m}" & vbCrLf & _
"123"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
direction(0) = 1#: direction(1) = 1#: direction(2) = 0#
' Create the tolerance object in model space
Set toleranceObj = ThisDrawing.ModelSpace.AddTolerance(textString, insertionPoint, direction)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddTolerance()
;; This example creates a tolerance object in model space.
;; Define the tolerance object
(setq insertionPoint (vlax-3d-point 5 5 0)
direction (vlax-3d-point 1 0 0))
;;"{\Fgdt;r}%%vasdf{\Fgdt;l}%%vdf%%vxc%%v12{\Fgdt;m}%%vsd"
(setq textString (strcat "{\\Fgdt;r}%%vasdf{\\Fgdt;l}%%vdf%%vxc%%v12{\\Fgdt;m}%%vsd\n"
"{\\Fgdt;t}%%vdfd%%v3dd{\\Fgdt;l}%%vv%%v%%vxc{\\Fgdt;m}\n"
"123"
;; Create the tolerance object in model space
(setq toleranceObj (vla-AddTolerance modelSpace textString insertionPoint direction))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 04:13
