AddText 方法 (ActiveX)
创建单行文本。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddText(TextString, InsertionPoint, Height) 言论没有其他评论。 例子VBA: Sub Example_AddText()
' This example creates a text object in model space.
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Define the text object
textString = "Hello, World."
insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddText()
;; This example creates a text object in model space.
;; Define the text object
(setq insertionPoint (vlax-3d-point 2 2 0)
textString "Hello, World."
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 01:23
