AddSphere 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 892| 评论: 0|原作者: admin|来自: AutoCAD
创建给定中心和半径的球体。
RetVal = object.AddSphere(Center, Radius)
类型:块、模型空间、纸空间
此方法应用到的对象。
中心
访问:仅输入
类型:变体(双打的三元素阵列)
指定球体中心点的 3D WCS 坐标。
半径
访问:仅输入
类型:双
球体的半径。必须为正数。
返回值 (RetVal)
类型: 3DSolid
作为新创建的球体的对象。3DSolid
Sub Example_AddSphere()
    ' This example creates a sphere in model space.
    Dim sphereObj As Acad3DSolid
    Dim radius As Double
    centerPoint(0) = 5#: centerPoint(1) = 5#: centerPoint(2) = 0#
    radius = 5#
    Set sphereObj = ThisDrawing.ModelSpace.AddSphere(centerPoint, radius)
     ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_AddSphere()
    ;; This example creates a sphere in model space.
    ;; Define the solid sphere
    (setq centerPoint (vlax-3d-point 5 5 0)
          radius 5)
    (setq sphereObj (vla-AddSphere modelSpace centerPoint radius))
    ;; Change the viewing direction of the viewport
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-27 04:59
