AddShape 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 918| 评论: 0|原作者: admin|来自: AutoCAD
基于由名称、给定插入点、比例因子和旋转标识的模板创建 Shape 对象。
RetVal = object.AddShape(Name, InsertionPoint, ScaleFactor, Rotation)
类型:块、模型空间、纸空间
此方法应用到的对象。
名字
访问:仅输入
类型:字符串
要插入的形状的名称。
插入点
访问:仅输入
类型:变体(双打的三元素阵列)
要插入形状的 3D WCS 坐标。
比例因子
访问:仅输入
类型:双
要应用于形状的比例因子。使用 1.0 指定无刻度。必须为正数。
旋转
访问:仅输入
类型:双
要应用于形状的旋转角度(以弧度为单位)。
返回值 (RetVal)
类型:形状
新创建的对象。Shape
在添加 Shape 对象之前,必须使用该方法加载包含所需形状的文件。LoadShapeFile
Sub Example_AddShape()
    ' This example creates a BAT shape from the ltypeshp.shx file.
    ' Load the shape file containing the shape you wish to create.
    ' Note: Replace the ltypeshp.shx file name
    ' with a valid shape file for your system.
    On Error GoTo ERRORHANDLER
    ThisDrawing.LoadShapeFile ("C:/Program Files/AutoCAD/Support/ltypeshp.shx")
    Dim shapeObj As AcadShape
    Dim shapeName As String
    Dim scalefactor As Double
    Dim rotation As Double
    ' "diode" is defined in es.shx file
    shapeName = "BAT"
    insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
    scalefactor = 1#
    rotation = 0#       ' Radians
    ' Create the diode shape object in model space
    Set shapeObj = ThisDrawing.ModelSpace.AddShape(shapeName, insertionPoint, scalefactor, rotation)
    Exit Sub
ERRORHANDLER:
    MsgBox "Cannot find the shape file.", , "AddShape Example"
(defun c:Example_AddShape()
    ;; This example creates a BAT shape from the ltypeshp.shx file.
    ;; Load the shape file containing the shape you wish to create.
    ;; Note: Replace the ltypeshp.shx file name
    ;; with a valid shape file for your system.
    (setq shapeFile ".\\ltypeshp.shx")
    (if (/= (findfile shapeFile) nil)
        (progn
	           (vla-LoadShapeFile doc (findfile shapeFile))
            ;; "diode" is defined in es.shx file
            (setq insertionPoint (vlax-3d-point 2 2 0)
                  shapeName "BAT"
                  scalefactor 1
                  rotation 0)      ;; Radians
            ;; Create the diode shape object in model space
	           (setq shapeObj (vla-AddShape modelSpace shapeName insertionPoint scalefactor rotation))
        (alert "Cannot find the shape file.")
GMT+8, 2026-10-27 04:55
